Spoon exhaust users
Hey all! Quick question for the spoon exhaust users. Mine came in the mail today. As they no longer come with the test pipe should this system still be %100 bolt on to the stock cat? This might seem like a noob-like question but I just want to make sure I dont run into an issue. Thanks for all the info in advance.
i have the spoon exhaust w/out test pipe. easy install. unbolt tie bar, unbolt stock exhaust, put spoon on (don't forget the gasket), put tie bar back on (tighten to oem specs) and your ready. i recommend the silencer because your ears will be deaf without it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco »</TD></TR><TR><TD CLASS="quote">Spoon is loud no matter what. Im sure a TP will reduce drone a little, but the main thing is it will free up some descent power and weight.</TD></TR></TABLE> lols 5-6 pounds + 2hp. i'd probably run it if my damn state wasn't full of hippy democrat tree hugging politicians.
anyhoo....can't wait to hear your reaction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K »</TD></TR><TR><TD CLASS="quote"> lols 5-6 pounds + 2hp. i'd probably run it if my damn state wasn't full of hippy democrat tree hugging politicians.
anyhoo....can't wait to hear your reaction. </TD></TR></TABLE>
test pipe will probably add 5-8hp. The stock cat is fairly heavy, I would say maybe 20-30lbs. A test pipe can weigh all of 5lbs.
hahaha. Look @ me foolio. Your not the only one in So Cal. Im down in San Diego, and I'm still running a test pipe. It smells good
See, They make the rules. I break em'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OBSeRiouSo »</TD></TR><TR><TD CLASS="quote">
i'll be the guy holding the box of tissues when you get your ticket
</TD></TR></TABLE>i'll be the guy holding the box of tissues when you get your ticket
portable smog testing station ftl
saw it before in person
</TD></TR></TABLE>portable smog testing station ftl
Quik Chris
Mar 24, 2004 08:14 AM
