Can the brake shields be removed?
Old May 9, 2002 | 04:00 PM
fire7882's Avatar
Default Can the brake shields be removed?
Can the shield that is located behind the disc brake be removed. Why is it there and what will the adverse side effects be of taking it off?? I have my entire suspension off and the shield ore bent up pretty bad and i wanted to remove them.
Old May 9, 2002 | 04:52 PM
gymkhana's Avatar
Default Re: Can the brake shields be removed? (fire7882)
yes. you need to take the rotor off to acces three phillips head screws. you need a little right angle screw driver or grab them with some pliers.
pros- more heat dissapation
cons- more water soak when wet(bite is weak at first until rotor dries.)
- possible heat damage to balljoint and cv boots and grease iv'e heard if driven on a hard track day.
mine are off for a couple years and no problems
Old May 9, 2002 | 05:21 PM
fire7882's Avatar
Default Re: Can the brake shields be removed? (gymkhana)
thanks. i think mine will be coming off
Old May 9, 2002 | 07:19 PM
civic dx's Avatar
those are dust shelds . dirt might get in there w/o them and make your brakes squill.
Old May 9, 2002 | 07:24 PM
tonyxcom's Avatar
Default Re: Can the brake shields be removed? (autoejcivic)
they are too keep brake dust out of the axle bearings i think.
take em off, your brakes will cool better.
ProStreetDriver
Suspension & Brakes
May 13, 2016 09:06 PM
Civic_07
Suspension & Brakes
May 5, 2008 09:31 PM
globy123
Aug 15, 2007 05:27 PM
Steve91
Feb 3, 2003 07:10 PM
