Bad ECT sensor causes no start?
Old Nov 29, 2006 | 12:21 AM
hmtcrxsir's Avatar
Default Bad ECT sensor causes no start?
I was wondering if anyone ever had a bad ECT sensor and causes the engine to not able to start? I think im having the same symptoms.
Old Nov 29, 2006 | 06:28 AM
hondaman86's Avatar
Default Re: Bad ECT sensor causes no start? (hmtcrxsir)
I've had a similar problem in cool weather and when I would finally get it to start after about 10 minutes of cranking, I would rev it up and it would bog down and turn off again. I found that the wires for my ECT were cut, I hooked it up and problem went away. A bad ECT will cause it to run way too rich.
Old Nov 29, 2006 | 02:21 PM
hmtcrxsir's Avatar
Default Re: Bad ECT sensor causes no start? (hondaman86)
it had a difficult time starting or it wouldnt start at all?
Old Nov 29, 2006 | 08:54 PM
jdeemseerx's Avatar
it might start once for a couple seconds, shut down and then not start ...open loop
Old Nov 29, 2006 | 11:32 PM
hmtcrxsir's Avatar
Default Re: Bad ECT sensor causes no start? (jdeemseerx)
i think im having the same problem. wasnt sure if its the ECT
Old Nov 30, 2006 | 01:35 AM
carlsberg's Avatar
i had to replce my ect sensor, but only due to cel code 6. It cause the engoine not to start, but had to turn it for a lot longer when the engine was cold
aznjay510
Apr 29, 2019 08:13 AM
fezzik
Aug 15, 2008 03:49 AM
DAintegration
Apr 30, 2007 02:53 PM
