how to fix my coolant leaks?
I have a small leak on the radiator and also on the heater control valve and would like to know from you guys whether you would replace both or just keep on adding coolant on the reservoir? I usually add coolant every 2 weeks. This is my DD.
Also, I need to know how to replace the heater control valve and where is this under the hondaautomotiveparts.com section if anyone knows?
Thanks.
Thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91accordwagon »</TD></TR><TR><TD CLASS="quote">I have a small leak on the radiator and also on the heater control valve and would like to know from you guys whether you would replace both or just keep on adding coolant on the reservoir? I usually add coolant every 2 weeks. This is my DD.
Thanks.
just replace it and stop being a cheap skate.
just wait until it breaks down on the interstate on your way to work, while the wife and family is the car.
it's under heater core, or something
Thanks.
xlusiveracer
30
Feb 10, 2017 11:49 AM
wtcchonda
Oct 12, 2013 11:26 AM
crex23
Nov 3, 2009 06:08 AM
