skunk2 stage 1 cams w/ stock valvetrain
Old Nov 28, 2006 | 07:52 PM
BoostinEJ1's Avatar
Default skunk2 stage 1 cams w/ stock valvetrain
i've searched and i've come to the conclsuion these can be ran on a stock itr valvetrain? ive decide after alot of thought that i dont want to mess with my valvetrain so i was thinking about either ctr cams or s2s1 cams. i have s2s2 cams now but i know in order to put them in i have to replace the valvetrain and i no longer want to do that. i just want my hatch to be fun to drive an semi-quick. thanks
p.s. with these cams do they have to be tuned to run? obviously to get the most out of them that is obvious but can then be run without like CTR cams?
Modified by Fresh EG at 11:42 AM 12/3/2006
Old Nov 29, 2006 | 12:25 AM
zerogravitycrx's Avatar
Default Re: skunk2 stage 1 cams w/ stock valvetrain (Fresh EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fresh EG &raquo;</TD></TR><TR><TD CLASS="quote">i've searched and i've come to the conclsuion these can be ran on a stock itr valvetrain? ive decide after alot of thought that i dont want to mess with my valvetrain so i was thinking about either ctr cams or s2s1 cams. i have s2s2 cams now but i know in order to put them in i have to replace the valvetrain and i no longer want to do that. i just want my hatch to be fun to drive an semi-quick. thanks</TD></TR></TABLE>
i have s2s2 cams and they are ridiculous insane, but at the same time i went with all new valve train. ss valves, titanium retainers and springs. sell your s2s2 cams, if you dont want to upgrade your valve train. then buy the skunk2 stage 1 cams and you'll be fine w/ your stock valvetrain. less tuning and produce quick mid range power, like the way you want it!
Old Nov 29, 2006 | 03:31 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: skunk2 stage 1 cams w/ stock valvetrain (zerogravitycrx)
Just stay with the stock revlimiter and he's completely right.
Old Nov 29, 2006 | 04:42 AM
jdmB18CT-R's Avatar
Just stop holding back and invest in the new SK2 PRO2 VT and try it out on either your SK2 st1 or SK2 st2. I can almost bet that after you install those cams on your stock VT, your gonna want to change out your VT and REV that hell out of your HONDA. After all what are all honda motors have in common? Don't cheat yourself
Old Nov 29, 2006 | 05:15 AM
black_EM1's Avatar
Community Builder
Default Re: skunk2 stage 1 cams w/ stock valvetrain (jdmB18CT-R)
And for those of us without money?
Old Nov 29, 2006 | 06:24 AM
SkoundrelUSA's Avatar
cute little bastard
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zerogravitycrx &raquo;</TD></TR><TR><TD CLASS="quote">
i have s2s2 cams and they are ridiculous insane, but at the same time i went with all new valve train. ss valves, titanium retainers and springs. sell your s2s2 cams, if you dont want to upgrade your valve train. then buy the skunk2 stage 1 cams and you'll be fine w/ your stock valvetrain. less tuning and produce quick mid range power, like the way you want it!</TD></TR></TABLE>
I have s2s2 also. I wouldn't say they're ridiculously insane though lol. They're alright. Kinda wanna try Pro 1s instead
Old Nov 29, 2006 | 07:02 AM
jdmB18CT-R's Avatar
Default Re: skunk2 stage 1 cams w/ stock valvetrain (black_EM1)
This sure is an X-pensive hobby then
It never ends.............................................. .................................................. .................................................. .................................................. .................................................. .................................................. .. . .. . . .. . . . ........................................... .. ... ... . .... .................................................. .........................
Old Nov 29, 2006 | 07:07 AM
BoostinEJ1's Avatar
i dont want to replace the VT. end of story
Old Nov 29, 2006 | 07:34 AM
Boots's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmB18CT-R &raquo;</TD></TR><TR><TD CLASS="quote">. After all what are all honda motors have in common? </TD></TR></TABLE>
no torque? i had to do it lol
Old Nov 29, 2006 | 12:01 PM
RP215.'s Avatar
Default Re: (Fresh EG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fresh EG &raquo;</TD></TR><TR><TD CLASS="quote">i dont want to replace the VT. end of story</TD></TR></TABLE>
Me neither, so I guess it's safe to go pick up a set of these? Cam gears and some tuning?
edit: and im assuming these &gt; oem type r cams?
Old Nov 29, 2006 | 12:12 PM
2001B18C1GS-R's Avatar
ok i have had these cam stage one and just sold them
you can run them with stock valvetrain but using your 8200 rpm rev limiter but i went with just spring skunk2 springs and oem retainer and reved up to 85ish maybe 87oo with tune on crome so i like it those cam are sick for some quick easy power
Old Nov 29, 2006 | 12:55 PM
Ketone's Avatar
Default Re: (2001B18C1GS-R)
I ran them on stock valvetrain and they are fine, but keep it at the factory rev limit. The stage 1 is a good cam; you should be happy with the results.
Old Nov 29, 2006 | 04:51 PM
BoostinEJ1's Avatar
so im guessing as long as i stay under 8500 i can use these just fine?
Old Nov 30, 2006 | 01:51 PM
SHUTTLE's Avatar
the Skunk2 stage 1 cam is alittle bigger then the TYPE R you will be fine using your stock valve train you will be happy with them but if you do decide to build it go with the PRO1 cams and raise the comp it will have great power
Old Dec 1, 2006 | 02:42 AM
RP215.'s Avatar
Thanks :]
Old Dec 1, 2006 | 03:59 AM
98vtec's Avatar
moderator emeritus
Default Re: (RP215.)
one misshift and bye bye.
Old Dec 1, 2006 | 06:32 AM
black_EM1's Avatar
Community Builder
Default Re: (B.Rabbit)
True story.
Old Dec 3, 2006 | 07:42 AM
BoostinEJ1's Avatar
can these be run without a tune?
Old Dec 3, 2006 | 01:22 PM
98vtec's Avatar
moderator emeritus
why are you even installing them? Your not going to be happy with them until you get it tuned.
Old Dec 3, 2006 | 01:43 PM
BoostinEJ1's Avatar
because i have no cams in the car. i plan to get a tune i just want to know if like CTR cams they can be run without?
Old Dec 3, 2006 | 02:34 PM
ChicagoMike's Avatar
Yes they can.
Old Dec 4, 2006 | 03:05 AM
BoostinEJ1's Avatar
we'll ill be trading my s2s2 for s2s1 so hopefully ill be alright
Old Dec 4, 2006 | 05:36 AM
EG-B20vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B.Rabbit &raquo;</TD></TR><TR><TD CLASS="quote">one misshift and bye bye.</TD></TR></TABLE>
Bullshit... I would repetitively go to 9200K and misshifted several times.
Still running like a champ. B20vtec 5 years old now. 50k+ miles never a single problem.
BTW I'm running stock B16a2 Valvetrain which consists of Duals on Intake, Singles on Exhaust.
But this is Honda-Tech so maybe all the E-motors blowup with one misshift.
Old Dec 4, 2006 | 06:48 AM
I'm also going to have to disagree. I had a pretty terrible misshift, 5th to 2nd. I broke two motor mounts, but didnt do any damage to the motor itself.
Old Dec 4, 2006 | 07:50 AM
black_EM1's Avatar
Community Builder
Default Re: (AddictiveAllMotor)
4th to 3rd at ~120. Scared the **** out of me.
