b series tb on D series intake?
Old Nov 28, 2006 | 06:06 PM
97grnrs's Avatar
Default b series tb on D series intake?
i heard a b series ls TB will bolt onto a D series intake mani. is this true and if so which combos are possible
Old Dec 5, 2006 | 04:26 PM
Brick Top's Avatar
Default Re: b series tb on D series intake? (97grnrs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97grnrs &raquo;</TD></TR><TR><TD CLASS="quote">i heard a b series ls TB will bolt onto a D series intake mani. is this true and if so which combos are possible </TD></TR></TABLE>
i believe all b-series TBs will bolt to a d-series ex style manifold.
Old Dec 5, 2006 | 04:27 PM
s10cky's Avatar
a buddy of mine put a b16 throttle body on his d-series sol so yea its been and can be done.
Old Dec 6, 2006 | 11:08 AM
allnaturalb16's Avatar
Default Re: (s10cky)
what about b16 injectors and maybe even the manifold?
Old Dec 6, 2006 | 05:06 PM
s10cky's Avatar
manifold. no. injectors, not sure. maybe change clips and machine a bigger port for the injector.
Old Dec 6, 2006 | 07:24 PM
Redline130's Avatar
A B-series T/B will not bolt up to a D16A6 or D16A1 intake manifold. Not sure why you would want to swap injectors, they flow the same.
Old Dec 11, 2006 | 06:26 PM
97grnrs's Avatar
Default Re: b series tb on D series intake? (Redline130)
i just got a b18b tb and it is a real close fit to bolt up to a d16a6 mani.. if i drilled out the stock mounting holes about an 8th of an inch it would fit right on
cpl rampage
23
Apr 22, 2009 03:44 AM
hondakid4dr
Mar 11, 2008 09:05 PM
RipSiTurboHatch
Oct 27, 2005 12:09 PM
boosted k20
Jan 10, 2005 01:38 PM
up2spd
Jun 21, 2004 09:13 AM
