Tire leak
Old Nov 28, 2006 | 05:32 PM
Raf99's Avatar
Default Tire leak
Hey. Not even year old rims, 205x40x17 tires on. Front left loses air only after taking turns fast. Had the tire re-sealed on. If I drive normally, rather slow, it takes about a month. Only tire that does it. Also no bends in the rim and pressure goes down below 30psi.
I started noticing this about 2 weeks ago. Maybe just the tire?
Any suggestions?
Old Nov 28, 2006 | 06:35 PM
old man neri's Avatar
Default Re: Tire leak (Raf99)
Could be a number of things. Have you checked to see if you ran over a screw or something? What is the rate of loss?
Old Nov 28, 2006 | 09:31 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire leak (old man neri)
I think neri is right. It sounds like a puncture, probably from a nail rather than a screw. (Nails tend to leak slower.) Take it to a tire shop. They'll examine it, and if it's not obvious, they can wet the outside with soapy water to look for leaks.
Old Nov 28, 2006 | 09:34 PM
vtecsi00's Avatar
Default Re: Tire leak (nsxtasy)
another option could be that you have a bead leak as well or as everyone has stated a puncture
Old Nov 28, 2006 | 09:55 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: Tire leak (vtecsi00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecsi00 &raquo;</TD></TR><TR><TD CLASS="quote">another option could be that you have a bead leak as well or as everyone has stated a puncture </TD></TR></TABLE>
True. A tire shop can catch a bead leak - a leak between the tire and the wheel, at the bead - the same way as with a puncture, looking for bubbles. This year I actually had a leak that turned out to be a slightly damaged tire, with a leak in the tire itself, near the bead (damaged in an unintentional off-track excursion). Any good tire shop should be able to find the leak.
If it's due to a puncture along the tread, which is the most common cause of leaks, they can probably repair the tire for $10-15.
Old Nov 29, 2006 | 01:48 AM
Raf99's Avatar
Thanks for all the suggestions guys. The tire shop i was at did check for leaks, but didn't find any. This maybe due to the air only being lost when the tire is under load. But, I am going to take another look at it.
irod630
Honda Civic (2006 - 2015)
14
Mar 7, 2008 06:38 AM
BDogggUT34
Nov 9, 2007 09:15 AM
tonezilla
Jan 26, 2006 08:52 AM
metal-x
Jun 20, 2003 08:40 AM
Eluzion
May 29, 2003 07:22 AM
