Oil catch can off of valve cover???
Old Nov 28, 2006 | 05:21 PM
em1si's Avatar
Default Oil catch can off of valve cover???
i am going to install an oil catch can on my ls-vtec with the plug coming from the exaust side of the valve cover near cylinder # 2....
1. just curious if anyone has done this before to alleviate excesses pressure buildup in the head?
2. How did it work for you?
3. How much oil would come out during normal daily driving (under 3500rpm) on average weekly? How much when racing??
btw...it's a stock obd1 ls block with a 2001 gsr head...any help would be greatly appreciated...
also i'm looking for a affordable oil catch system...i saw weapon r had one 4 $50...i figure they all work the same for this kind of thing as it's not really a "performace part" correct me if i'm wrong...
thanks
Old Nov 28, 2006 | 08:37 PM
em1si's Avatar
Default Re: Oil catch can off of valve cover??? (lsvtec-sleeper)
anyone?????
Old Nov 29, 2006 | 10:14 AM
Mike@K-Tuned's Avatar
In my opinion, with your low compression mild build motor the stock PCV system is all you need. If you had more compression and larger cams you might begin exceed the ability the stock PCV system.
Old Nov 29, 2006 | 07:39 PM
em1si's Avatar
but it's already overwelming the stock pcv valve all day...
Old Nov 29, 2006 | 08:24 PM
del_slow420's Avatar
Default Re: (lsvtec-sleeper)
how do u no this has your dipstick blown out yet?
Old Nov 30, 2006 | 07:54 AM
em1si's Avatar
Default Re: (del_slow420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_slow420 &raquo;</TD></TR><TR><TD CLASS="quote">how do u no this has your dipstick blown out yet?</TD></TR></TABLE>
no it hasn't, but i am runnin extremly high and un normal oil pressure on the gauge...usto peak at 80psi when i got on it, and around 90-95 psi if i was beating the hell outta it...then around 30-40psi at idle depending on how hard i was driving...not it' at about 60 when at idle...and it is off the chart at throttle...not sure whats up but i think it's being overwelmed with pressure..
Old Nov 30, 2006 | 08:07 AM
You have another issue there. Is the stock PCV system hooked up properly?
civic_66
Apr 2, 2009 04:12 PM
peanuts8888
Jan 19, 2007 09:42 AM
vtec.dc2
Sep 10, 2003 10:08 PM
J337_UNIT
Sep 4, 2003 12:47 PM
