pillar guage wiring... firewall wiring 98 prelude sh
Old Nov 28, 2006 | 05:11 PM
LSRracing95's Avatar
Default pillar guage wiring... firewall wiring 98 prelude sh
how would i go about wiring 2 pillar gauges in a 98 prelude sh?
where can i easily go through the firewall to wire to the distributor for a tach?
where does the a/f guage wire tap into on the ecu?
i am wiring air/fuel gauge and pillar sized tachometer in this car.
where should i tap for power for each gauge and where is the best grounding point?
thank you
Old Nov 28, 2006 | 05:15 PM
SteveoBA8's Avatar
Default Re: pillar guage wiring... firewall wiring 98 prelude sh (LSRracing95)
Use a volt/ohm meter to find a good ground and power supplies.
It's not that hard to find a grommet to go through or drill yourself a hole and put in a grommet.
Old Nov 28, 2006 | 06:11 PM
pinecone's Avatar
The A/F gauge taps into the O2 sensor, if I remember corectly.
Old Nov 29, 2006 | 06:23 AM
Default Re: pillar guage wiring... firewall wiring 98 prelude sh (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Use a volt/ohm meter to find a good ground and power supplies.
i was just wondering if anyone knew specific spot on the firewall where the grommet was, i am used to working on integras and i know this would be different im just trying to get ahead here so i have an idea of what im getting into before i start...
i was thinking of getting power from a fuse that has power when the ignition is on, like a radio fuse or something.. and i was thinking of just grounding both to the same bolt somewhere around the fuse box..
Old Nov 29, 2006 | 06:24 AM
Default Re: pillar guage wiring... firewall wiring 98 prelude sh (pinecone)
into the o2 sensor? okay i thought it was tapped into the ecu.. that is how my dad did my a/f gauge in my integra.. but the o2 could be a better choice.. how would i tap into the o2 sensor for the gauge without ruining it?
Old Nov 29, 2006 | 01:04 PM
i have these three wires left..
tachometer- 12v yellow
accessory green to dist.
air/fuel- accessory purple to o2 sensor
whats the best way to get them through the firewall i.e. what side of the firewall should i drill? where?
and how do i tap it into the distributor and how do i tap it into the o2 sensor?
which fuse should i tap for power? i have it on the starter signal 7.5amp now.. but that doesnt seem correct?? please helpp!!!
ramboPandA
Mar 27, 2016 07:51 PM
92vteclude
Audio / Security / Video
Dec 23, 2005 08:35 AM
RideOrDie
Sep 22, 2005 09:19 AM
alex_b
May 11, 2003 06:17 PM
