VAFC Help Needed!
Old Nov 28, 2006 | 03:28 PM
Mohsin's Avatar
Default VAFC Help Needed!
Hello All,
Unfortunatly lost my VAFC settings, throttle % not working (Do i need to "self learn"?).
Car: EG6 SiR
Mods: HKS Intake / RSR*GT2 exhaust / Test Pipe
Can anyone recommend settings that I should use? Not too sure what it was on previously.
Also what sensor type settings should I have?
Thanks.
Old Nov 28, 2006 | 03:56 PM
Mohsin's Avatar
Also when doing the throttle learning for 10 seconds, is the voltage meant to change a lot? when i press accel for 10 seconds the thr voltage stays near enough the same.
This has happened after the alarm was installed by a dealer. help!
Old Nov 29, 2006 | 01:05 AM
Mohsin's Avatar
Bump for help
Old Nov 30, 2006 | 08:58 AM
Mohsin's Avatar
can anyone help with the mods on car?
Old Nov 30, 2006 | 02:03 PM
Prostreet80's Avatar
Default Re: (Mohsin)
i know this might not be much help to you, but if you call up the tech department at apexi they can help 714 685 5700
sleepyH22
Nov 12, 2006 09:30 PM
