Code 6 and 22. D16z6 No start! Help!
Old Nov 28, 2006 | 02:48 PM
hmtcrxsir's Avatar
Default Code 6 and 22. D16z6 No start! Help!
Well, my car overheated and the bypass hose burst and i had to replace it. So i replaced it and everything was running smoothly. Then before you know it the car started sputtering and just dies off. I tried to start it again but it wouldnt turn over. There was no check engine light or whatsoever. So i jump the ECU anyways, and the check engine light starting flashing. It flashes 22 and 6. I wasnt sure if the VTEC pressure sensor and ECT Water Temperature Sensor would cause the car not able to start. Could the ECT cause the engine to not start?
bstaralways
Sep 4, 2007 02:51 PM
ANONYMOUSdeecee
Mar 7, 2007 07:47 PM
LScivic_wpg
May 27, 2006 10:10 PM
compwc18
Oct 19, 2004 05:01 PM
