I NEED HELP PLEASE!! NEW BATTERY/STARTER CAR WONT START!
Old Nov 28, 2006 | 01:52 PM
96_LS's Avatar
Default I NEED HELP PLEASE!! NEW BATTERY/STARTER CAR WONT START!
Hi guys Iam new here to honda-tech and to the scene so xcuse me if I sound really Newbish. Well to make dis long story short Ill start by saying, my car (Automatic) turned off 3weekz ago next day it was completely dead, so i bought a new battery, still wouldnt start, so i bought a new starter and now all it does it sounds like something is spinning and its prettyloud, I think its the starter teeth not hitting the flywheel i think. Iam frustrated already help me please tell me wutchu guys think is going on
Old Nov 28, 2006 | 01:59 PM
cnydc2's Avatar
Default Re: I NEED HELP PLEASE!! NEW BATTERY/STARTER CAR WONT START! (96_LS)
So the starter is turning but it isn't turning the engine over? I'd start by making sure the starter is completely tightened to bell housing and if it is pull it off and inspect the teeth on the flywheel. That might help, it might not. Good luck bro
Old Nov 28, 2006 | 02:59 PM
KBG Indey's Avatar
you could also pull the starter out and just try to start the car with it out of the trans, to make sure the gear shoots out, and spins properly then goes back into the starter
Old Nov 28, 2006 | 05:50 PM
Jay J's Avatar
Prince of Zamunda
Default Re: (IndeyAttack)
Check your starter grounds
Old Nov 29, 2006 | 07:26 AM
96_LS's Avatar
thnx guys i tried everything and it still not working same spinning noise...
Old Nov 29, 2006 | 07:28 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
describe what happened before you replaced the battery and starter. Would it crank over at all when you tried to start it? Did it just die while driving?
Old Nov 29, 2006 | 08:35 AM
BLK_TEG_007's Avatar
check out whats inside were your starter might go does your torque converter looks like it still has teeth plus there is a ground that sits on your tranny check it outmake sure its tight and if youre batt is the one going out check your altenator
Old Nov 29, 2006 | 08:48 AM
cranny's Avatar
24.224.233.247
Default Re: (BLK_TEG_007)
take your dizzy cap off and see if your rotor is spinning when you turn the engine over. or just take a plug out and see if it sparks with the wire on it. i know this sounds funny , but it sounds like you have a broken timing belt. it will make the car sound different(awful) when turning over. like its turning too fast. whining.
Old Nov 29, 2006 | 09:46 AM
Community Builder
Default Re: (cranny)
He said he turned it off one day, and the next day it wouldn't start, so I doubt it's the timing belt.
Old Nov 29, 2006 | 10:00 AM
96_LS's Avatar
Default Re: (PatrickGSR94)
before i replaced the starter and the battery, I was driving the night before going home and just out of nowhere it felt like i downshifted and just redlined so i stopped, put it in park turned it off then turned it back on, put it in drive and pressed the gas and it just redlined again the car didnt move, so i turned it off again let it sit for a while then tried turning it on again and didnt do anything only the power would go on but engine wouldnt turnover so i had it towed home, and the next day the car was just completely dead no power, so i decided to change battery and starter..
boosted timebomb
May 9, 2007 11:11 PM
96_LS
Nov 28, 2006 02:17 PM
skinnyshugg
Sep 5, 2006 08:51 PM
RCautoworks
Jan 17, 2003 10:19 PM
lilcasino
Jun 26, 2002 07:21 PM
