ECU Question
Im doing a transmission swap in my D15B7 motor with an EX transmission from the same year.
I was just wondering if an ECU from D16Z6 which has Vtec will work with my transmission swap, my motor which is nonVtec.
Just wondering because after the transmission swap I plan of doing a mini-me.
Thanks Everyone
Thanks Everyone
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">The transmission is purely mechanical. The ECU has no effect on it. </TD></TR></TABLE>
couldnt say it any better
a ecu change, will cause you to have a bad idle...if u put the vtec ecu on a non vtec motor
couldnt say it any bettera ecu change, will cause you to have a bad idle...if u put the vtec ecu on a non vtec motor
