Valve adjustment question
Old Nov 28, 2006 | 10:31 AM
vtec.dc2's Avatar
Default Valve adjustment question
while doing valve adjustment, i'm not sure if i aligned everything on the dot per cylinder... so lets say if i rotated too far and missed by one tooth, will that make a difference? what type of difference would it make?
thanks
Old Nov 28, 2006 | 12:48 PM
walker111's Avatar
Default Re: Valve adjustment question (vtec.dc2)
It all depends on how far you were off. Take the feeler guage for instance, look how small/precise the clearance needs to be. IMO, take the vc off and re-do the adjustment.
Old Nov 28, 2006 | 12:51 PM
andyt's Avatar
Default Re: Valve adjustment question (walker111)
I found that the marks on my cam gears don't exaclty equal TDC like it says in the Helms.
Now I just stick a long screwdriver down each cyl. and find it the old fashioned way...
Old Nov 28, 2006 | 12:53 PM
walker111's Avatar
Default Re: Valve adjustment question (andyt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">I found that the marks on my cam gears don't exaclty equal TDC like it says in the Helms.
Now I just stick a long screwdriver down each cyl. and find it the old fashioned way...</TD></TR></TABLE>
Thats what I do. Then its your fault if its off
Old Nov 28, 2006 | 03:54 PM
an2ny888's Avatar
i don't think you have to be right on the dot... just make sure you're on the round part of the cam ( before it becomes a lobe )
Old Nov 28, 2006 | 05:09 PM
vtec.dc2's Avatar
Default Re: Valve adjustment question (an2ny888)
can you elaborate.. on the old fashion way??
Old Nov 28, 2006 | 08:56 PM
andyt's Avatar
If you put something, like a long screwdriver, down the cylinder, then as you turn the engine over you will see it rise, and when it stops moving up, but before it begins to move down, then you are at TDC for that cylinder. Its more accurate than trusting the cam gear marks!
Old Nov 29, 2006 | 01:26 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andyt &raquo;</TD></TR><TR><TD CLASS="quote">If you put something, like a long screwdriver, down the cylinder, then as you turn the engine over you will see it rise, and when it stops moving up, but before it begins to move down, then you are at TDC for that cylinder. Its more accurate than trusting the cam gear marks!</TD></TR></TABLE>
when you say down the cylinder.. where exactly do i place the screw driver.. i just want to be sure before i recheck
Old Nov 29, 2006 | 01:58 AM
Bart-EK's Avatar
you take out a spark plug and put the long screwdriver in the hole... it will rest on top of the piston...
Fighterinsnatch
16
Jul 26, 2007 08:02 AM
garyc17
May 4, 2007 08:29 PM
silentblackhat
Dec 27, 2004 06:49 PM
311
Jul 12, 2004 09:35 AM
Chubz
Jul 8, 2002 12:31 PM
