Interior Lights and Radio - Too Dim?
Old Nov 28, 2006 | 10:07 AM
ShinobiLude's Avatar
Default Interior Lights and Radio - Too Dim?
I cant remember because I just got my car back and its been a year but I believe that my interior lights...like the gas meter and the temp gauges are too low at night when the lights are on. During the day if i have my lights on i cant even see the gauges at all. Are you gauges the same?
Also i dont know if this is related but my radio wont activate either. It has power...I can flp he face and eject and put in CD's but the radio wont acutally turn on. Was just working a week ago though...Clock is on. Fuse isnt blown. Could this all be related to a ground issue? Thanks!
Old Nov 28, 2006 | 02:18 PM
M@'s Avatar
M@
Default Re: Interior Lights and Radio - Too Dim? (ShinobiLude)
There is a dimmer that you can adjust to make the guages brighter. If I have the lights on when its bright out, I always flip the dimmer to the brightest setting. It makes the guages as bright as when the lights are off.
For the sterio, it sounds like you may have a problem with the (+12v)acc connection. There may be a seperate fuse for that inline. To test you really would just need to pull the player, and run a seperate +12v. If that makes the CDP work then you need to trace the loss of voltage.
Old Nov 28, 2006 | 07:10 PM
Default Re: Interior Lights and Radio - Too Dim? (M@)
Yeah there is a seperate fuse under the dash for the ACC...I'll double check that fuse but i didnt think that was blown.
It's weird...the dimmer dial works...but doesnt make it all that bright at night. And i believe it has something to do with the cd player not getting enough power either. I'll have to find the culprit.
Old Nov 28, 2006 | 07:13 PM
M2B4's Avatar
what year is ur lude? i know both of my 92's i cant see the gauges in the day if i have the lights on. i used to think something was wrong but both of mine do it...which is why im trying to change to el gauges.
Old Nov 29, 2006 | 07:51 AM
Default Re: Interior Lights and Radio - Too Dim? (M2B4)
1992 Prelude S baby. (JDM H22 Swap boyeeee) I like to see those gauges...sometimes i drive with my lights on during the day in VA since people are idiots out here. The lifted 90ft Dogde rams sometimes cant see my Lude.
sam0218
Nov 19, 2006 04:32 PM
mel
12
Nov 9, 2006 09:04 AM
pinoyboy204
Feb 22, 2004 06:38 PM
Orison21
Feb 21, 2004 03:28 PM
AMBGUOS
Jan 25, 2004 12:04 AM
