K24 race motor 300+hp socal need to sell
Motor
Tsx block K24A2 sleeved
Wiseco 15.1 compression 89.5 bore
IB rods 99mm stroke
99mm stroke knife edged and balanced by Castillo’s crankshafts
type-s modified oil pump
HEAD
Type s head
Supertech valve, springs, and retainers
Type s cams
Dtr headers
Custom intake
1000cc rc injectors
bdl fuel rail
Bbk throttle body
Hondata gasket
Trans
Type s
4.7 Final
type r lsd
Clutch twin disc quartermaster
Custom flywheel
Axles
Hondata kpro
Engine harness modified for injectors
Primary o2/af
Shifter and cables + ****
Aluminum bushings
Starter
Coils
Valve cover
K24chain cover and chain
Vtc gear new
11G's in the swap
sell it all for 8 asap
Jason
562-307-6552
Modified by Chain Driven at 8:57 PM 11/29/2006
Modified by Chain Driven at 9:39 PM 12/12/2006
Modified by Chain Driven at 12:34 PM 12/17/2006
IB rods 99mm stroke
HEAD
Type s head
Type s cams
Dtr headers
Custom intake
1000cc rc injectors
bdl fuel rail
Bbk throttle body
Hondata gasket
Trans
Type s
4.7 Final
type r lsd
Custom flywheel
Axles
Hondata kpro
Primary o2/af
Aluminum bushings
Starter
Coils
Valve cover
Vtc gear new
11G's in the swap
Jason
562-307-6552
