99 LS swap into EK problem
Old Nov 27, 2006 | 10:06 PM
ekx4's Avatar
Default 99 LS swap into EK problem
ok well, just finished up the swap, new plugs, wires gaskets timing belt, all that stuff.. heres the problem, when im at a stop sign and leaving in first gear, from 1-3k it lags like krazy feels like the car doesnt want to move but after that it feels fine, im running obd2a-obd1 jumper with obd1 ls ecu... the guy i got the motor from said he had a problem with it running on 3 cyclinders because of the injector #2 so i wired it direct car runs a bit better but still 1-3k lags doesnt feel like i have any power what so ever... im pretty stummped to this point.. check for spark fuel air everything is there... could it be a intake manifold leak? tps? injector stuck on open? bad o2 sensors? im running out of ideas..
Old Nov 27, 2006 | 10:07 PM
ekx4's Avatar
Default Re: 99 LS swap into EK problem (ekx4)
oh yeah, also i have no cels, when i run obd2a ecu no cels either.
also what are the spark plugs suppoes to be gapped at? .030? or .050?
im kinda leaning towards a fuel problem? since.. i unplugged the spark plug wire #3 and the motor doesnt seem to shake or sound like it wants to die, but on all the other cyclinder it does that..
one more thing, i pulled out my plugs, and they kinda look brownish white on the tips, my friend said im running hella rich
Old Nov 27, 2006 | 10:42 PM
ekx4's Avatar
Old Nov 27, 2006 | 11:48 PM
fmrprojects's Avatar
change out your map sensor. and did you wire the injector staright to the ecu or to the battery. you dont want a injector on all the time
Old Nov 28, 2006 | 02:23 AM
Loi-Tech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekx4 &raquo;</TD></TR><TR><TD CLASS="quote">oh yeah, also i have no cels, when i run obd2a ecu no cels either.
one more thing, i pulled out my plugs, and they kinda look brownish white on the tips, my friend said im running hella rich</TD></TR></TABLE>
from what i bolded it sounds like you have a burnt valve. my friend has the same problem on his h23 motor, when we pull cylinder 3's sprak plug wire it'll still idle the same and won't sputter or sound like it wants to die, we get spark and fuel to that cylinder. he is also running on 3 cylinders...runs like ****!
Old Nov 28, 2006 | 09:39 AM
ekx4's Avatar
Default Re: 99 LS swap into EK problem (Loi-Tech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loi-Tech &raquo;</TD></TR><TR><TD CLASS="quote">
from what i bolded it sounds like you have a burnt valve. my friend has the same problem on his h23 motor, when we pull cylinder 3's sprak plug wire it'll still idle the same and won't sputter or sound like it wants to die, we get spark and fuel to that cylinder. he is also running on 3 cylinders...runs like ****!</TD></TR></TABLE>
so what should i do then?
Old Nov 30, 2006 | 01:02 PM
Loi-Tech's Avatar
so what should i do then?</TD></TR></TABLE>
if its a burnt valve then you gotta pull the head and change the valve that has a hold in it.
jdmdreamz414
19
Jul 19, 2011 12:09 PM
Ls_eg6
Aug 4, 2008 03:14 PM
crazyimport
Mar 7, 2008 10:57 AM
98_EL
Dec 14, 2006 11:26 PM
CLE
Jun 9, 2006 06:21 PM
