milling heads
Old Nov 27, 2006 | 09:42 PM
4doortypeR's Avatar
Default milling heads
Whats the most that can be safely milled from a b16a head or B18c head
before the head is no good or Reaches the stop?
Does every 0.010 = .3 compression ?
Old Nov 28, 2006 | 06:42 AM
Fezzie's Avatar
Default Re: milling heads (4doortypeR)
im not 100% sure but i believe its .020 or .030 is the max
Old Nov 28, 2006 | 06:50 AM
GarageAlchemist
Guest
Posts: n/a
Default Re: milling heads (Fezzie)
yea i hear .30 but i don't know first hand
Old Nov 28, 2006 | 07:00 AM
bluedlude's Avatar
Default Re: milling heads (GarageAlchemist)
i know its not what you are looking for, but the max service limit on an H22 head is 0.2 mm
Old Nov 28, 2006 | 07:43 AM
drift4jesus's Avatar
Default Re: milling heads (bluedlude)
I've seen b16/itr heads milled. 080" by members that frequent this forum. You better have some custom pistons for this and know what the expletive you are doing.
Old Nov 28, 2006 | 12:34 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
i personally ran my built pr3 head with 40 thou milled off
Old Nov 28, 2006 | 07:09 PM
..........'s Avatar
Default Re: milling heads (S@nt0s)
well im running 5cc dome wiseco piston with gsr head milled .040, had to clayed the motor for clearance, just get high compression piston to bump up your cr where u want it. just my .02
Old Nov 28, 2006 | 07:32 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: milling heads (..........)
my chambers were reshaped (welded) as well.. CC's on chamber was 39.6
remember tho for about every 20 thou -1 degree on the cams to Zero out the cams to the block..
b20powereDA
Jan 27, 2006 08:35 PM
KOREAN
14
Apr 5, 2005 04:49 PM
Y2A
Mar 4, 2005 09:03 AM
Anthonyl469
Jun 24, 2004 06:37 AM
Mr. Softee
Aug 21, 2001 12:55 PM
