Turbo GSR exhaust question
Old Nov 27, 2006 | 04:32 PM
02Type-S's Avatar
Trades A lot!!
Default Turbo GSR exhaust question
Hey hows it going? I have the greddy 18g kit with 550s on my 95 gsr. The car was tuned using crome pro on an open downpipe. I have been driving it with stock piping from the dp back and no axle back. Would it be worth it to go ahead and jump on a cheap catback for now or would the gains not be worth it? I plan on going the kteller route but I can pick up a used catback locally for dirt cheap and just wanted to know if it would be a good purchase.
Old Nov 27, 2006 | 06:03 PM
boostedbigguy's Avatar
Default Re: Turbo GSR exhaust question (02Type-S)
did you say you were running the stock exhaust? if you are def get something else, im running the kteller, but if all you can afford is that cat back, go that route, you will see gains, maybe not crazy but gains none the less
Old Nov 27, 2006 | 07:07 PM
02Type-S's Avatar
Trades A lot!!
Default Re: Turbo GSR exhaust question (boostedbigguy)
The car currently has the greddy dp and the stock exhaust to where the axle back would bolt up (no axle back currently installed).
Old Nov 27, 2006 | 08:47 PM
aaronISthrowed's Avatar
It will make better gains, i would deffently stay away from the stock exhaust when going turbo. Better yet you could just run open downpipe and no exhaust at all.
Old Nov 28, 2006 | 10:23 AM
02Type-S's Avatar
Trades A lot!!
Default Re: Turbo GSR exhaust question (aaronISthrowed)
it was open downpipe but it was a little loud for daily driving.
Old Nov 28, 2006 | 10:27 AM
BoostedEG6's Avatar
check with a local exhaust place and see how much they would charge you for doing it from the DP back with mandrel bends.... I think that will be your best bet or you could look around here and see what you can find.... I would get rid of the stock piping though
Old Nov 28, 2006 | 12:49 PM
02Type-S's Avatar
Trades A lot!!
Default Re: Turbo GSR exhaust question (BoostedEG6)
i just got the hayame catback for cheap, it will do for now. It is 2.36" piping so it should be decent. I would go to a local place but nobody around here does mandrel bends, just crush bent.
Old Nov 28, 2006 | 12:57 PM
BoostedEG6's Avatar
go to Napa or a autoparts store and ask if they have mandrel U bends... you should only need 2 or 3 depending on the car...
Old Nov 28, 2006 | 03:48 PM
02Type-S's Avatar
Trades A lot!!
i work at advance actually, we do not carry anything in 3". I may go to a couple of other parts stores tomorrow.
Old Nov 29, 2006 | 08:23 AM
92gsrteg's Avatar
funny, we have almost the same setup, im runnin jdm gsr with modified greddy 18g kit and also tuned on crome pro.....i just got the thermal 3 inch exhaust and its sick and pretty damn quiet, my car is the quietest honda around and everyone loves it, no ricey sound here, just throaty power sound..........u should get it expensive but well worth it.
so simple
Jan 11, 2008 01:32 PM
1329itr00
Sep 5, 2006 01:36 PM
[Ennis_D]
Nov 20, 2004 11:03 AM
Dengar
11
Jun 11, 2003 06:07 AM
ITRyder
Jul 3, 2002 01:24 AM
