H22 aftermarket parts question ????????????????
Old May 9, 2002 | 12:26 PM
eg6madness's Avatar
Default H22 aftermarket parts question ????????????????
(1) Has JUN , TODA , Skunk 2 released any cams for the H22 Vtec ?
(2) Does golden eagle offer block sleeving for the H22 ?
(3) Who offers pistons for the H22 ?
(4) Are there any aftermarket manifolds for the H22 ?
(5) What exactly is need for the H22 to be placed in a 93 Civic Hatch ? (mounts, etc)
(6) Were can all the parts need to make the swap easier be found ?
(7) Who makes LSDs for the H22 ?
(8) Are there any aftermarket final drives for this motor ?
[Modified by eg6madness, 4:36 PM 5/9/2002]
Old May 9, 2002 | 12:35 PM
hybridreams's Avatar
Default Re: H22 aftermarket parts question ???????????????? (eg6madness)
Skunk2. Yes. Whoever, custom. Yes. http://www.hasport.com http://www.driveshaftshop.com Take it to a shop.
Old May 9, 2002 | 01:33 PM
Sonic's Avatar
1. Don't know, you can get JDm Type S cams
2. Probably
3. JDM type S, Endyn, custom, maybe JE
4. Not sure, maybe Skunk2
5. Mount kit, wiring harness changes, complete swap, accord int shaft, integra axles, cut holes in the car, etc. Looka t the hasport page or get the SCC from a few months back that had it.
6. Hasport and junkyards
7. Honda, in Japan many H22's had an LSD. Other than that try Quaife, Kaaz
8. not sure, but you can always have one custom made.
Just to warn you, the H22 isn't as nice a swap as the B18/b20, the extra 100 lbs is an issue and some have issues with breaking axles. Also, no A/C or PS, and you ahve to cut holes in the car to convert to the cable style shift linkage.
Old May 9, 2002 | 05:14 PM
Mikey3000's Avatar
1. JUN and Skunk 2
2. Yes
3. JE, Wiseco, Arias, Endyn, pretty much everybody
4. what kind of manifold? intake? yes STR. Exhaust? yes everybody.
5. a mount kit, a custom wire harness, different axles, radiator, small fan.
6. look yourself
7. Quaife, Kaaz, Cusco
8. probably not. if so, maybe Quaife.
russlan44
Northern California (Sales)
17
Aug 24, 2010 07:42 AM
ExtraBlackRex
May 19, 2010 04:29 PM
hondacj7
Jul 4, 2008 11:45 PM
Artifactr
Nov 26, 2001 02:49 PM
