Socal Electrionics.
willing to trade the amp for some camber kits,ASR lower subframe Brace, JDM ITR 23mm rear sway bar,plus cash on your side depends on the conditions.
$200
*BRAND NEW IN BOX*
Performance Teknique Amp.
Model ICBM 779
<U>Features:</U>
Maximum Output Power @ 2 Ohms: 600W x 2CH
Power Output @ 2 Ohms: 240W x 2CH
Power Output @ 4 Ohms: 170W x 2CH
Power Output Bridged: 480W x 1CH
THD: 0.02% @ 2 Ohms, 0.1% @ 4 Ohms
Signal to Noise Ratio: >95dB
Frequency Response: 15Hz to 40kHz
Crossover: Separates
High-pass: 50Hz to 1kHz Variable
Low-pass: 30Hz to 500Hz Variable
Slope: 24dB Octave
Subsonic Filter: 10Hz to 100Hz Variable
Bass Boost: 0 dB to 18dB Variable
Input Sensitivity: 200mV to 6V Variable
Low level Input Impedance: 47K Ohm
Damping Factor: 180 into 4 Ohm
Channel Separation: >80dB
High & Low Level Input through RCA
Double Sided PCB
Dual Protection (Thermal & Short Circuit)
RCA Line Out
Power & Diagnostic LED Indicator
2 Ohm Stable
Soft Delayed Power On
Tri-Mode Capability
Power Supply Consumption (Bridged RMS): 57A
Fuse Rating: maxi 60A
Dimension (WxHxL): 9.96" x 2.12" x 17.71"
2. *BRAND NEW IN BOX*
$60
Seagate 250GB barracuda ATA HD internal hardrive.
ULTRAL ATA/100
7200RPM
16MB Cache
3.5-inch Drive
PC or Mac.
3. *BRAND NEW*
*40 OBO*
Sealed Sub Box Fit perfectly for a single 12" sub
PICK UP ONLY
$200
*BRAND NEW IN BOX*
Model ICBM 779
<U>Features:</U>
Slope: 24dB Octave
Double Sided PCB
RCA Line Out
2 Ohm Stable
Tri-Mode Capability
$60
ULTRAL ATA/100
7200RPM
16MB Cache
3.5-inch Drive
PC or Mac.
3. *BRAND NEW*
*40 OBO*
PICK UP ONLY
