FS: 4 channel amp, DC manual transmission mounts, flywheel
Old Nov 27, 2006 | 12:41 PM
HxC_TegGirl's Avatar
Default FS: 4 channel amp, DC manual transmission mounts, flywheel
**Concept CA-604 4 channel amp: $149 + shipping OBO. It has a few little scratches. It was only in my car for a little over a year and works perfect. I wanted a bigger amp so replaced it with an Eclipse XA4000. I bought it brand new for $289.99. Comes with instruction manual and extra fuses.
Description:
RMS Power 60W x 4 @ 4 Ohm
RMS Power 90W x 4 @ 2 Ohm
RMS Power 180W x 2 @ 4 Ohm MONO
Signal-to-noise ratio: 100 dB <--compare to other brands Kicker, MTX, etc.
Frequency Response: 5Hz - 50kHz
Total harmonic distortion: 0.05%· <--compare to other brands Kicker, MTX, etc.
Continuously variable 0 - 18dB BASS boost
Built-in continuously variable 18dB per octave crossover
Remote bass level control “port”
(remote RM-100 available separately)
Input sensitivity: 200mV - 8V
Backlit CONCEPT logo (blue)
Platinum connectors
Dimensions: L x W x H: 300mm x 296mm x 60mm l 11.82" x 11.66" x 2.37"
**Stock flywheel out of a 94 LS with 109k mi. Needs resurfacing. $30 shipped anywhere in the U.S. I also have a stock clutch only used for a couple months out of the same car if anyone wants that.
**I have (2) 5spd DC (94-01 Integra) TOP transmission mounts/brackets. Each is $25 shipped to anywhere in the U.S.
I have a 100% ebay rating under hxc_teggirl and a 5/5 team-integra.net buyer/seller rating under the name redTEGchick.
Modified by HxC_TegGirl at 11:29 PM 12/1/2006
Old Nov 27, 2006 | 04:09 PM
bump
Old Nov 27, 2006 | 04:34 PM
prjctwhteg's Avatar
Default Re: (HxC_TegGirl)
the that amp would hide up under a seat out of an em1?
Old Nov 27, 2006 | 05:05 PM
Default Re: (prjctwhteg)
I dunno, I had it mounted on the back of my back seat in my teg.
Dimensions: 11.82" x 11.66" x 2.37"
Old Nov 28, 2006 | 10:17 AM
ttt
Old Nov 29, 2006 | 01:17 PM
bump
Old Dec 1, 2006 | 08:29 PM
m.glisson003
Audio / Security / Video
18
Aug 15, 2011 06:17 PM
HxC_TegGirl
Dec 1, 2006 08:30 PM
PYITR821
Apr 25, 2005 06:38 PM
tca0bell
Feb 27, 2005 09:17 AM
CHONCH
Sep 10, 2003 09:43 PM
