Suspension & Brakes Theory, alignment, spring rates....
rack & pinion problem....replacements?
Old Nov 27, 2006 | 12:01 PM
ekeddie's Avatar
Default rack & pinion problem....replacements?
not sure if this is a repost? i searched but no luck. i keep havin to replace my right front wheel bearing, its the third time this year, my left side bellows boot is ripped, with almost no more grease on the inside, im pretty sure my rack & pinion is almost gone bc there is a deep click and much roughness. im told i must replace the whole setup, possibly the outer tie rods might be bent. my question is are there cheaper aftermarket rack & pinion setups to replace the stock one bc dealer cost a grip. btw its a 2000 honda civic dx hatchback(ek9) any insight would be much appreciated thanks
Old Nov 27, 2006 | 01:11 PM
Tyson's Avatar
Default Re: rack & pinion problem....replacements? (ekeddie)
yeah, jsut get a rebuilt rack. since its power, you really cant rebuild it yourself.
personally, i would prefer to buy a honda refurbed unit, but i understand its always more costly. not sure what the expense is compared, but sometimes it is worth it tho, like getting an alternator from honda than autozone.
what makes you think the tie rods are bent?
Old Nov 27, 2006 | 04:44 PM
ekeddie's Avatar
well i ripped out the power steering setup. plus i was tryin to find a reason why i changed the bearings 3 times in one year, bent tie rod could possibly throw the hub all wack putting pressure on the bearing i suppose, thanks for ur input
Old Nov 27, 2006 | 04:45 PM
Tyson's Avatar
Default Re: (ekeddie)
bent tie rod? no, that would mess up your alignment. did you have alignment issues?
however, vibration from a loose rack would help cause the bearing to fail prematurely.
i think im dealing with that right now, my passenger wheel bearing is on its way out and for a while i had a loose rack before i replaced my steering rack end bushing (manual steering rack). so that makes sense to me.
Old Nov 28, 2006 | 11:27 AM
ekeddie's Avatar
appreciate it dude
Tom B
May 3, 2017 12:27 PM
jayzeno
Apr 27, 2011 03:33 AM
91GEDHATCH
11
Dec 19, 2010 11:52 AM
BB1vtec
Dec 16, 2005 05:59 PM
speedaholic92
Jan 22, 2004 03:24 PM
