FS: Rocket Motorsports M24x, do you have enough balls?
i got a set of low milage Rocket Motorsports M24x cams. I purchased it with my car but i want something a little more streetable. If your engine has enough *****, then these are the cams to get.
the suggested compression to run these are are 12:1 however im running 11.5:1 and its fine, just make sure you have a good tuner. Also prefered is a larger displacement motor. 2.0+ is good but im running 1.9L and its fine. Again, the key to these cams are to get a good tuner.
Intake Duration: 298
Intake Lift: 12.7
Exhaust Duration: 305
Exhaust Lift: 12.1
Intake Valve Events @ 0.050
Opening: 29 BTDC
Closing: 53 ABDC
Peak Lift .472
Lobe Center: 102
Exhaust Valve Events @ 0.050
Opening: 21 ATDC
Closing: 61 BBDC
Peak Lift .472
Lobe Center: 110
Intake Lift: 12.7
Exhaust Lift: 12.1
Opening: 29 BTDC
Closing: 53 ABDC
Peak Lift .472
Lobe Center: 102
Opening: 21 ATDC
Closing: 61 BBDC
Peak Lift .472
Lobe Center: 110
RESURRECTED
Dec 27, 2005 09:06 PM
RESURRECTED
Dec 27, 2005 05:41 PM
