LS/Vtec allMoTor Setup.
Old Nov 27, 2006 | 11:35 AM
stpacura's Avatar
Default LS/Vtec allMoTor Setup.
My goal is to reach close to the 200 if not the 200whp mark its self.
HEAD
b16 head
arp head studs
JGE complete valve train(Valves(flat stainless steal), Springs(dual valve springs, and Retainers(titanium))
Skunk 2 stage 3 camshafts
JGE Cam Gears
Skunk2 Intake manifold & throttle body 68mm
Ls Injectors
Golden Eagle Ls/vtec kit
Headers
Tri-y headers. What yall think?
94 Ls Block
12:1 je cp pistons
arp rod bolts
act xact streetlite flywheel
act 6puck clucth kit
Ecu
p28 chip and tuned
Other
255 walbro fuel pump
Tranny
still Ls tranny for NOW
B16 WILL BE NEXT STEP.
REMEBER MY GOAL IS 200WHP. the closer the better.
what yall think NOw
Modified by stpacura at 2:27 PM 11/27/2006
Old Nov 27, 2006 | 12:14 PM
Juggernaut 2's Avatar
Default Re: LS/Vtec allMoTor Setup. (stpacura)
I think you will over cam the motor Stage 2's will be be fine with that compression.
Old Nov 27, 2006 | 12:31 PM
BILLY_BLING's Avatar
way to much cam for that setup!!
Old Nov 27, 2006 | 12:49 PM
doood's Avatar
been there done that
Default Re: LS/Vtec allMoTor Setup. (Juggernaut 2)
go with rm m22x, skunk2 pro1 or pro2, and 310cc injectors. and a nice rage header.
Old Nov 27, 2006 | 01:26 PM
stpacura's Avatar
I'm thinking of using some high cp piston 12:1. What yall think will that be good with the cams. cause I already started buying and I got them already.
Old Nov 27, 2006 | 02:28 PM
should make a nice power with high comp. pistons
Old Nov 28, 2006 | 06:39 AM
Fezzie's Avatar
the s2s3 are designed for higher comp. motors, s2s2/blox2 would be right for that comp.
Old Nov 28, 2006 | 07:16 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: LS/Vtec allMoTor Setup. (Fezzie)
W3rd. S3s are a bit too much for that motor.
And don't forget at least 310cc injectors.
Old Nov 28, 2006 | 07:34 AM
D-Rob's Avatar
Default Re: LS/Vtec allMoTor Setup. (black_EM1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BILLY_BLING &raquo;</TD></TR><TR><TD CLASS="quote">way to much cam for that setup!!</TD></TR></TABLE>
Even though people are recommending something even bigger, like the Skunk2 Pro2+'s?
If you've already got the S2S3's, keep them. They'll do just fine.
- Derek
Old Nov 28, 2006 | 10:23 AM
Fezzie's Avatar
Default Re: LS/Vtec allMoTor Setup. (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">
- Derek</TD></TR></TABLE>
ya keep them it wil be ok
Old Nov 28, 2006 | 10:45 AM
RaceCarRyne's Avatar
stage 2 wil be the best choice
eaglebeak88
Oct 4, 2011 07:16 PM
seldon
Sep 28, 2008 02:09 PM
crxsimike
Feb 14, 2006 12:07 AM
