Going to flush my brake sys, should I use a 'better' fluid than OEM Honda?
Just replacing my front rotors, and getting better brakes pads all around, and I was planning on sticking with Honda's brake fluid, but should I 'upgrade' to a better fluid while I'm at it? This will only be for the street with maybe an autocross or two. What do you suggest? Oh, and I have a 99 GSR. Thanks.
ATE Super Blue
[Modified by MrFatBooty, 9:54 PM 5/9/2002]
i think ATE gold has the same properties or better though, not sure since i always trusted my superblue and if i couldnt get that, MOTUL 600.
I believe the NSX uses a better grade of fluid. See if they can use that. I believe it is more of a racing fluid to prevent boiling.
BLUE or GOLD , same crap diff color , ones DOT legal , ones not
both good
both good
How could a brake fluid not be DOT legal? It's just a fluid w/ a high boiling point that is resistant to moisture absorption. ????????
Kinda OT, but it's real easy to tell you're old fluid from the new when the old is almost black.
Someone before me didn't pay too much attention to the brakes.
BTW I am using ATE Type 200 (the gold).
itr1244
May 17, 2004 01:31 PM
ILUVTEC
May 13, 2002 04:02 AM
