5th Gen ABS removal ?
Old Nov 27, 2006 | 09:01 AM
lude98SH's Avatar
Default 5th Gen ABS removal ?
I have posted this same topic a few times and searched many times and have not found much. I have found that you must run new brake lines, proportioning valve and brake booster. Obviously the lines I can do myself but where am I going to get the rest of the stuff, will the 4th gen stuff work and also have the same stopping power ?
Old Nov 27, 2006 | 09:06 AM
mgags7's Avatar
You can use any choice of proportioning valve, a 4g one would work fine
You don't need a different brake booster, the only reason we change them on the 4g is because the master cylinder is different....you're just going to have a hell of a time getting all the fittings the right size...
Old Dec 5, 2006 | 11:29 AM
lude98SH's Avatar
Default Re: (bb4ever)
ok so i dont have to change the whole brake booster. Hmmm ......I found a master cylinder from a 4th gen without abs but in order to run that I would need to change the brake booster to a 4th gen correct and also run new lines?
http://www.nopionline.com/nopi...elude
I also found this thread which explains things alittle better but isnt prelude specific.
https://honda-tech.com/zero...50285
Modified by lude98SH at 12:39 PM 12/5/2006
Old Dec 5, 2006 | 12:46 PM
mgags7's Avatar
The master cylinder has nothing to do with the ABS system....the only reason you have to change them is because the non-abs 4g preludes use different fittings on the brake lines
So, you can keep your current master....all you need is a prop. valve and to run lines...
Old Dec 5, 2006 | 01:38 PM
lude98SH's Avatar
I could run a non abs axle with everything removed correct ? Also will I always have an abs light ?
Old Dec 9, 2006 | 11:41 AM
lude98SH's Avatar
Default Re: (lude98SH)
bump
Old Dec 9, 2006 | 01:23 PM
clemsoncb7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">I could run a non abs axle with everything removed correct ? Also will I always have an abs light ? </TD></TR></TABLE>
Yes you can run an non-abs axle, the only difference is in the small teeth along the circumfrence of it. You also will always have an abs light unless you remove the bulb
Max
lude98SH
Jun 24, 2007 10:31 AM
lude98SH
Nov 6, 2006 07:53 AM
kornerk12
Sep 5, 2006 05:22 PM
clemsoncb7
May 13, 2005 04:06 AM
TypeSH
Jul 7, 2003 02:03 PM
