Buddy club spec 3 cams on stock valve train
I know this has been discussed proably about a million times but I searched and didnt find out what I need. I was wondering if anyone has had any problems with using these cams on the stock valve train?
when i eventually put mine in, im gonna put in the B/C valves & head gasket and obviously the pulleys but from what i've read the standard itr valve train will be fine as power is made within the standard rev range with only a small increase in lift
if anyone could advise me on whether my oem injectors will be up to the job or not, i'd appreciate it,tanx
'97 jdm B18c with above mods
The stock ITR valve train should be fine. I have seen more than one case of bent valves etc. with BC3's and stock B16 valve train though.
