CRX SiR Airbox fit USDM CRX?
Old Nov 27, 2006 | 03:57 AM
JohnnieChimpo's Avatar
Default CRX SiR Airbox fit USDM CRX?
I realize there is a intake pipe that feeds up through the radiator support but how does the rest of it fit?
I thought I read on here once that the box was bigger and didn't leave room for the battery, but I can't find that thread.
Old Nov 27, 2006 | 10:36 AM
91jdmcrx's Avatar
Default Re: CRX SiR Airbox fit USDM CRX? (JohnnieChimpo)
I have a jdm sir crx airbox on my crx hf it fits tight but not too bad
Old Nov 27, 2006 | 12:34 PM
nutz4cycling's Avatar
Default Re: CRX SiR Airbox fit USDM CRX? (91jdmcrx)
yeah, it fits ok, the mounting brackets dont line up at all, but it does fit, tightly, with the stock battery. I can go out and take a pic if you want.
Old Nov 27, 2006 | 05:12 PM
Default Re: CRX SiR Airbox fit USDM CRX? (nutz4cycling)
Hmm, so it'll be a tight fit but won't bolt down?
Did you guys mount the lower resonator and the intake tube that runs up to the radiator support?
I'd really like to hook all that "unseen" stuff up to help quiet the car down.
Old Nov 30, 2006 | 05:24 AM
Anybody?
Old Nov 30, 2006 | 06:05 AM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutz4cycling &raquo;</TD></TR><TR><TD CLASS="quote">yeah, it fits ok, the mounting brackets dont line up at all, but it does fit, tightly, with the stock battery. I can go out and take a pic if you want.</TD></TR></TABLE>
thats bs it will bolt down but not all 3 bolts, just the main 2. Ill go take a picture right now. the lower resonator for the intake will not bolt on but i believe you can use an old one from a CRX or hatch. im going to go to the junk yard and buy one next week. But i dont see why it wont work. and the tube that goes thru the radiator support wont work. heres a pic from a front clip i had. you will have to beat the crap out of the part that is right above where the bumper bolts on
Old Nov 30, 2006 | 06:15 AM
Zaakro's Avatar
Default Re: CRX SiR Airbox fit USDM CRX? (Zaakro)
heres those pictures, on the first picture you can see in the bottom right corner where is doesnt bolt up. but the one on the top right and bottom left bolt on as long as you have the brackets.
Old Dec 11, 2006 | 01:57 AM
Hey thanks for the pics.
You said the resonator and other ducting won't fit. Would it fit with the SiR bumper?
Is there any way to take a picture of why it won't fit?
I would really like to quite the intake down.
Also would you sell me that power steering reservoir hose?
Old Dec 11, 2006 | 12:40 PM
oh, my bad, I didn't get the brackets with the one that i purchased, I just assumed the chassis was different. that is some good info there
Old Dec 11, 2006 | 03:58 PM
Zaakro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnnieChimpo &raquo;</TD></TR><TR><TD CLASS="quote">Hey thanks for the pics.
Also would you sell me that power steering reservoir hose?</TD></TR></TABLE>
I have the SiR front end and even with that it wont fit. the holes you use for the resonator to bolt up to are not there. but you can use the resonator from a USDM CRX or Hatchback and it will work.
And no you cant have my power steering reservoir
Modified by Zaakro at 7:23 AM 12/12/2006
ThaMatrix
Nov 20, 2006 07:31 AM
SINISTR
Nov 13, 2006 10:26 PM
Gant
Aug 21, 2005 08:13 PM
4gnhatch
66
Feb 7, 2004 02:18 AM
JCCOOL43
Jun 13, 2003 08:32 AM
