how to remove brake and gas pedals from 4th gen
Old Nov 26, 2006 | 08:28 PM
H22LUDE808's Avatar
Default how to remove brake and gas pedals from 4th gen
so im converting my car from auto to 5 speed. i took off all the bolts from my brake and gas pedal assembly because i will need to take them off. for some reason i cant get the brake pedal loose.
is it connected to something? cuz i cant see anything under there. theres no room and im kinda big so i get cramped when i stay under there long time. LOL.
but if anyone knows how to disconnect the brake pedal from whatever its connected to, please let me know.
thanks guys
Old Nov 26, 2006 | 09:25 PM
soundbomber's Avatar
Default Re: how to remove brake and gas pedals from 4th gen (H22LUDE808)
did you undo both the bolts on the firewall as well as the ones the clevis pin that connects it to the brake booster?
Old Nov 26, 2006 | 09:58 PM
Hawkze_2.3's Avatar
Yep, there's the bolts for the pedal frames and then the pin that connects the pedal to the booster and clutch master cylinder. Just remove the cotter pin and the pin slides out from the pedal.
Old Nov 26, 2006 | 10:03 PM
H22LUDE808's Avatar
oh ok. i removed all the nuts from the firewall bolts, but i cant seem to see the pin you guys are talking about. so for the gas pedal, all i gotta do is remove the throttle cable? and for the brake i gotta look for the pin, i take the pin out then it should come out?
also for install on the clutch pedal... how do i do the whole clutch master and slave cylinders?
thanks for the help guys.
rob
Old Dec 26, 2006 | 01:20 PM
pprowler6's Avatar
Default Re: (H22LUDE808)
is there any easy way to maneuver the pedals around the steering colume so i can take them out easier? I had a real tough time doing so and i dont know how im gonna get the new set in. Thanks
Old Dec 26, 2006 | 09:43 PM
pprowler6's Avatar
Default Re: (pprowler6)
i know there is people that did manual swaps...what u do for the pedals guys??
aznvietboi87
Jan 6, 2013 10:35 AM
Spikey640
May 18, 2008 09:09 AM
Fuster_Cluck
Mar 27, 2007 05:28 PM
B18C Turbo
Aug 30, 2006 12:46 PM
litterbox
16
Nov 7, 2005 01:56 PM
