Vacuum Routing Questions....
Ok guys, I could use a little help here on this...RLZ made john (the birdman - 250whp h22) anyways they made his custom IM with only 3 vac ports, 1 MAP, 1 FPR, and 1 T'd off to the brake booster and the IACV
We need to add some sort of catch can/pcv setup as there currently isn't one....and I drew up this diagram hoping it would work with just the 1 big port on the IM, but if we had to I suppose we could drill another hole in the IM...
My original thought was to get a vacuum log like the ITB guys....but if this will work its much simpler....I just wasn't sure if you can tee off like that or if each thing needs its own vac source....i assume they do....
let me know
let me know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">Im actually selling that vc....check the classifieds
That's where it went!
</TD></TR></TABLE>That's where it went!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob »</TD></TR><TR><TD CLASS="quote">Looks like it would work to me.
But wouldn't it just be easier/cleaner to have a vaccuum log and hide it under the manifold?
Thats what I originally thought....thanks for the help
If I can make john drop the $$ for a vac log I will....or I may just get some pvc pipe and make my own....hmmm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">I would vent the valve cover better.
Is that a sealed catch can?</TD></TR></TABLE>
So you think we ought to have fittings welded on and use those instead of the pcv?? That was the original plan but as always, john is trying to be a cheap ***
Yea is a sealed can, its the http://www.mckinneyraceworks.com one....
</TD></TR></TABLE>Thats what I originally thought....thanks for the help
Yea is a sealed can, its the http://www.mckinneyraceworks.com one....</TD></TR></TABLE>
Welding bungs would be the best way but you could drill/tap some fittings on the cover as well.
Pesonally I would vent the crankcase instead of trying to run a sealed catch can setup. I would keep it seperate from the IM/Booster/IACV.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">Where does the vacuum come from then? Or do you not need vac?</TD></TR></TABLE>
Not necessarly.
I run a filtered breather so it allows the crankcase to vent via three hoses connected to the valve cover. It does not connect to the IM (vacum) in anyway. I do however run a line from the breather to the header with a check valve to "pull" or create some negative pressure in the breather/crankcase.
Not necessarly.
Yeah pull is what I was looking for...I don't think the vent is going to do a whole lot without some sort of negative pressure....
I want to get john to get a slash cut nipple welded into the collector somewhere and get the check valve setup like you have, I remember you describing that back when you got the header on...
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever »</TD></TR><TR><TD CLASS="quote">Yeah pull is what I was looking for...I don't think the vent is going to do a whole lot without some sort of negative pressure....
thanks</TD></TR></TABLE>
the vent will allow the posative pressure to escape quickly. You will only get so much vacum from IM. I was surprised how much air was moving through the lines off the valave cover. Obviously blow by palys a role in this however I had to add hose clamps on very tight barbed hose fittings to keep the hoses from blowing off.
^^Well I picked up a custom -10 an fitting can last night. It wasn't cheap, but it has a filter/breather on top with two lines in, and internal baffles. One day, I might get a slash cut in my exhaust, but it will be "after" the collector... I can't cut into those beautiful tubes.
DAslow9
Aug 16, 2010 09:14 PM
liquid51
Nov 18, 2003 10:20 PM
