how to remove block n head
Old Nov 26, 2006 | 07:19 PM
KMk51188's Avatar
Default how to remove block n head
i got a d15b7 n i need to remove the head n block can screw do i need to remove to remove it please help
Old Nov 26, 2006 | 07:23 PM
EJgsr's Avatar
Default Re: how to remove block n head (KMk51188)
i have no idea what the fuuck you are asking.
Old Nov 26, 2006 | 07:25 PM
Eran's Avatar
HT White Ops
Take it to a mechanic, give them your keys, and agree to whatever work they want to do. Sign every piece of paper they give you.
Old Nov 26, 2006 | 07:31 PM
EJgsr's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">Take it to a mechanic, give them your keys, and agree to whatever work they want to do. Sign every piece of paper they give you.</TD></TR></TABLE>
Old Nov 26, 2006 | 07:38 PM
KMk51188's Avatar
Default Re: (USDMej1)
i cnt take it anywhere i crashed my hatch but the motor is still good i took off the valve cover and i need to know what screws to take out to remove the head
Old Nov 26, 2006 | 07:39 PM
Eran's Avatar
HT White Ops
The head studs.
Old Nov 26, 2006 | 07:43 PM
pdiggitydogg's Avatar
alright...
you need to:
drain the oil and coolant
pull the header
remove the timing belt
remove the dizzy
remove all the cam caps (10mm bolts) and camshafts/gears
remove the headstuds, in proper, alternating, stepped order
theyre not scews...theyre bolts
Old Nov 26, 2006 | 07:45 PM
EJgsr's Avatar
Default Re: (Eran)
there you go.
there a 14mm.
you turn them to the left.
Old Nov 26, 2006 | 07:47 PM
komat's Avatar
Default Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg &raquo;</TD></TR><TR><TD CLASS="quote">alright...
you need to:
pull the header
remove the dizzy
theyre not scews...theyre bolts</TD></TR></TABLE>
d series dont need to remove the cam caps
Old Nov 26, 2006 | 07:55 PM
EG2Driver's Avatar
that is one abused motor.
Old Nov 26, 2006 | 07:59 PM
EJgsr's Avatar
Default Re: (DeadEnd9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">that is one abused motor.</TD></TR></TABLE>
lol
its not mine.
mine has 2 cams.
Old Nov 26, 2006 | 09:04 PM
KMk51188's Avatar
any more diagrams on how to remove the block??
Old Nov 26, 2006 | 09:26 PM
VRD^don's Avatar
just take the whole motor out..that way you'll have the head, motor, trans all apart and out of the car..
Old Nov 26, 2006 | 10:00 PM
Minglor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">
there you go.
there a 14mm.
you turn them to the right.
Fixed.
Looking at them from above, you would turn them counter-clockwise
Turning the ratchet right
(unless I am 100% wrong and loosing my mind at 2am In that case carry on)
Old Nov 26, 2006 | 10:06 PM
KMk51188's Avatar
Default Re: how to remove block n head (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">just take the whole motor out..that way you'll have the head, motor, trans all apart and out of the car..</TD></TR></TABLE>
i dont got a cherry picker n the **** is jus sittin in my driveway how can i drop it without a cherry picker i was think leavin the car on jack stands n put the jack under neath the tranny jack it up losen all the bolts n tranny n mounts etc etc n let it come down would that work?
Old Nov 26, 2006 | 11:05 PM
k20EP3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KMk51188 &raquo;</TD></TR><TR><TD CLASS="quote">i got a d15b7 n i need to remove the head n block can screw do i need to remove to remove it please help</TD></TR></TABLE>
WTF are you serious??
Old Nov 26, 2006 | 11:12 PM
KMk51188's Avatar
Default Re: how to remove block n head (k20EP3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20EP3 &raquo;</TD></TR><TR><TD CLASS="quote">
WTF are you serious?? </TD></TR></TABLE>
anyways anyone else??
Old Nov 26, 2006 | 11:43 PM
Kafelatte's Avatar
why do you need to remove the head? if you want to know that bad why don't you just search the web. im sure there's like 154564161816586489 articles about it.
Old Nov 26, 2006 | 11:58 PM
strictly.business's Avatar
Banned
i dont know about your car, but i would go kick whoever the expletive conceived you right in the teeth.
Old Nov 27, 2006 | 01:56 AM
SoullessJapaneseMachine's Avatar
rofl insta-classic. sigged.
Old Nov 27, 2006 | 03:52 AM
Default Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">d series dont need to remove the cam caps</TD></TR></TABLE>
Whoops! I forgot which motor we were talking about!
my mistake
Old Nov 27, 2006 | 04:13 AM
s_18's Avatar
Download the Helms manual, and read through the relevant pages.
You'll have to disconnect some hoses, unclip some connectors, and loosen the head bolts...
Regarding the bolts, loosen them 1/3 turn at a time, in the following sequence:
3 5 9 7 1
2 6 10 8 4 &gt;timing belt side
This is described on page 6-28 in the factory service manual.
Old Nov 27, 2006 | 05:42 AM
EJgsr's Avatar
Default Re: (Minglor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Minglor &raquo;</TD></TR><TR><TD CLASS="quote">
Fixed.
(unless I am 100% wrong and loosing my mind at 2am In that case carry on)</TD></TR></TABLE>
yes you are loosing your mind.
Old Nov 27, 2006 | 08:30 AM
94civicsally's Avatar
Ummm... ill take that head if you get it out That'd be effin awesome!!!!!
I just want some/a head. lol
Really tho. That'd be great. PM/IM me if your interested in selling please.
aim= civicsally111
Old Nov 27, 2006 | 08:51 AM
AntiStock's Avatar
Buy a shop manual...it goes into the procedures in much detail.
Although...if you think your head was screwed onto the block, I'm not sure even the shop manual would help.
