Some Toda Cam ?'s
Old May 9, 2002 | 10:45 AM
sneakychaos's Avatar
Default Some Toda Cam ?'s
EDIT: I'm running B's before you read and wonder "whats he running."
What is the recommended injector size? I've read some posts saying you should definately upgrade injectors (sgT) and others saying you don't need to do anything but bump up your fuel pressure?
Also, what seems to work for most people in regards to FPR's? The B&M + gauge seems like the cheaper of the options for under 100$, but you have to cut off the top of the stock FPR. I've heard +'s and -'s about the AEM, too.
Last but not least valvetrain and compression. Obviously upgrading the valvetrain to raise rev limit, etc. is a must. (I'm running Spec B's., currently stock VT, stock ECU.).. whats everyone's opinions on compression, and the best CR to run?
[Modified by trooth, 2:45 PM 5/9/2002]
Old May 9, 2002 | 10:46 AM
B18CXr's Avatar
Default Re: Some Toda Cam ?'s (trooth)
stock injectors are fine till you begin to raise the rev limit.
Old May 9, 2002 | 10:48 AM
Default Re: Some Toda Cam ?'s (B18CXr)
The head is coming off this weekend for Portflow inners, ITR outers.. and I'm thinking of picking up Vegeta's harness and ECU chipped for B's.. (6300 VTEC, 9300 Revlimit)... Its either that, or go with the PowerFC sittin in the kitchen. (Just need to get my OBD2 B > A harness made.)
Whats suggested for that... thx.
[Modified by trooth, 2:48 PM 5/9/2002]
Old May 9, 2002 | 11:05 AM
B18CXr's Avatar
lude injectors will do fine
Old May 9, 2002 | 11:10 AM
kenji's Avatar
25 Year Member
Trooth,
If you need an OBD2v2 to OBD2 harness made I can do that for you. It is a plug and play install. Email me if you need one. Thanks.
-kenji
Old May 9, 2002 | 11:11 AM
AssPenny's Avatar
Default Re: Some Toda Cam ?'s (kenji)
Damn Kenji, right in there whoring your products huh?
Craig - Who gives a big to Kenji's kick *** work
Old May 9, 2002 | 11:14 AM
Trooth,
-kenji
Yah I know.. I'm the guy who ordered one and changed his mind. Haven't decided if I'm using that other ECU, or going with the PowerFC....
Old May 9, 2002 | 11:25 AM
Splat's Avatar
Collector-o-Guns and Drinker
*cough* fc *cough*
Pat, who wishes he could have pursued a full B build-up on his kaa
Old May 9, 2002 | 11:26 AM
AssPenny's Avatar
Default Re: Some Toda Cam ?'s (itr009)
Don't sell it then
Speaking of FC, anybody try the new AEM EMS yet? Some one is selling one in the classifieds.
Old May 9, 2002 | 11:28 AM
Default Re: Some Toda Cam ?'s (AssPenny)
Don't sell it then
Yah... it is many more options and is very in depth, however AEM's support and their documentation suck ***. Also, they haven't released and update in a few weeks, keep pushing it off.
Finally - if you log too much data while driving, it will hang their program and shut your car down while driving. Definately not on the top of my "EMS/DFI" list.
Old May 9, 2002 | 11:29 AM
AssPenny's Avatar
Sweet... that is a kick *** feature...
Craig - Who has been thinking of reverse engineering a power fc and making his own unix based ems
Old May 9, 2002 | 11:32 AM
Old May 9, 2002 | 11:34 AM
Splat's Avatar
Don't sell it then
Tell you what - give me seven grand to pay off my bills and another two g's for the build-up, and I'll keep it
Pat, who doesn't think buttcoin will give him almost 10 large
Old May 9, 2002 | 11:35 AM
AssPenny's Avatar
Sell your body
Craig - Who plans on selling his on idhitit.com Web camz own j00!
[Modified by AssPenny, 3:35 PM 5/9/2002]
Don't sell it then
http://www.capitolone.com - 0% interest for 1 year. Just add the 2g's for buildup into your existing. Mind as well spend it, cuz ya can't take it with ya.
Old May 9, 2002 | 11:37 AM
B18CXr's Avatar
AEM system is
Old May 9, 2002 | 11:43 AM
Big Phat R's Avatar
Higher fuel pressures will make up for lower flowing injectors - up to a point. You might also get better atomization at higher pressure. I've been running Spec B's with stock injectors for a while now using a fuel pressure riser and have had no "discernable" pinging. That's not to say there isn't any pinging.
I think the consensus is that the best cc/min for Spec b's is 310 or so. Combined with Hondata - that is your best setup. Some guys use higher flowing injectors like 440s and can make it work - but then you DEFINITELY need something like Hondata or a standalone ECU.
I think the strategy being employed with respect to using the higher flowing injectors is to reduce the duty cycle of the injector and decrease the chance of having one of your injectors fail at high rpms. It's also cheaper and less of a hassle than replacing the stock fuel pump.
[Modified by Phat Bastard, 4:43 PM 5/9/2002]
Old May 9, 2002 | 11:54 AM
Splat's Avatar
Chit. That's the kind of stuff that got me where I am right now.
Bought the Scout - on credit.
Modded the Scout - on credit.
Modded the R - on credit.
See the pattern?
note - I am not selling the R because I can't afford to keep it. I'm selling it because I can't afford to do anything with it
Debt-free + b00st is the way for me
Old May 9, 2002 | 11:55 AM
JPP's Avatar
JPP
Default Re: Some Toda Cam ?'s (Phat Bastard)
To complete what Mr. Bastard just said, you should definetly raise the compression ratio to get the most out of the spec B. Anything around 12:1 is good. I am personnaly running with 11.4:1 and I would be to chicken to raise it more. I will be dyno tuning shortly so i will see the HP I get.
The B&M FPR + gauge is a very good set-up. (no comment on the AEM).
Old May 9, 2002 | 11:57 AM
AssPenny's Avatar
Default Re: Some Toda Cam ?'s (JPP)
Compression ownz...
Craig - Who is wondering if the we-todd crew will help him put some 12:1's in when he does the lump sticks
Old May 9, 2002 | 04:09 PM
you should definetly raise the compression ratio ... I am personnaly running with 11.4:1
Just curious what you've done to raise your CR... deck block, higher comp. pistons, etc?
Old May 9, 2002 | 04:11 PM
See Sig. (Talon)
Old May 9, 2002 | 04:14 PM
guyuenvy's Avatar
wheres cheapest place for b and m gauge and fpr?
Old May 9, 2002 | 05:12 PM
mafay2's Avatar
New User
My guess would be JDM ITR pistons with a 2 pcs headgasket. You will get around 11.4CR with that!!
Old May 10, 2002 | 04:24 AM
JPP's Avatar
JPP
Default Re: Some Toda Cam ?'s (mafay2)
You guess good. It is a Spoon 2 layer headgasket to be more precise.
