Suspension & Brakes Theory, alignment, spring rates....
If caster can be adjusted?
Old Nov 26, 2006 | 05:26 PM
sophie2005's Avatar
Default If caster can be adjusted?
A mechanician told me that caster is set before it went out factory, and it cannot be adjusted in garage, is that right?
I heard that can be adjusted!
Old Nov 27, 2006 | 06:40 AM
b16a4's Avatar
Default Re: If caster can be adjusted? (sophie2005)
no you cannot adjust caster.
just toe.
Old Nov 27, 2006 | 12:15 PM
EK k kay's Avatar
Default Re: If caster can be adjusted? (b16a4)
With aftermarket products, caster can be adjusted.
Old Nov 27, 2006 | 05:13 PM
sophie2005's Avatar
Default Re: If caster can be adjusted? (EK k kay)
THANKS, My car is 97 honda accord. I heard that there is a cam on the UCA, and to turn the cam, the caster is adjust.
what after market product is that?
Old Nov 27, 2006 | 06:01 PM
Jago's Avatar
nope you can somtimes adjust a small amount by shimming the front radius rod
Eddie92gt
Apr 24, 2016 02:10 AM
Semir D
Jan 16, 2007 12:39 PM
MassCivicMan987
Jul 3, 2006 08:49 AM
Gump
Sep 20, 2004 03:09 PM
Drag-On23
Jan 11, 2004 06:27 PM
