My first ALL MOTOR build - LS/VTEC
Old Nov 26, 2006 | 04:52 PM
B16A1-EF9's Avatar
Default My first ALL MOTOR build - LS/VTEC
I bought this EK about 3 months ago. When I bought it it was stock height, had a carbon fiber hood and clear Altezza style tail lights.
By the second day that I owned it I installed OMNI Power coilovers, ROTA slipstream rims on Falken PT615 tires. I got JDM 96-98 tail lights. The car came with the original CX cluster that was painted blue for some reason. The previous owner was hardcore into RICE! lol
I got a CTR cluster right away. Since I have been building my new N/A motor for it. Anyone on here that knows me from before I have the 89 civic GSR on boost. I've been building that one for about 5 years now, so I've always been a boost guy, this will be my first attempt at ALL MOTOR.
Anyway, about the motor. I got an LS bottom-end and had it totally rebuilt with P30 B16 pistons that are 1mm oversized. I used ARP rod bolts to strengthen the stock rods. I have a Type R flywheel with a new Exedy Stage 1 clutch kit. I got a first gen b17 PR3 vtec cylinder head with Skunk2 valve springs and retainers. I got Skunk2 Pro1 cams and gears. I got TWM individual throttle bodies and a Rage "Hytech knock-off" tri-y header. The head has been cut about 15-thou....so I should have about 12-12.5:1 compression. Well here goes some pics....
Old Nov 26, 2006 | 05:34 PM
misaelmelchor's Avatar
looking good man... keep us posted... i wanted to know if its easy to tune? i heard the old itb's are...
Old Nov 26, 2006 | 05:35 PM
Orangecivic251's Avatar
Default Re: My first ALL MOTOR build - LS/VTEC (B16A1-EF9)
very similiar to my setup
Old Nov 26, 2006 | 06:35 PM
strict 9 ef's Avatar
Default Re: My first ALL MOTOR build - LS/VTEC (HondaEMS.com)
hey bruno it's NY
u have joined the dark side nowALL MOTOR
it looks top notch can't want to hear the itb's
here is another legend in the making for sure
Old Nov 26, 2006 | 06:38 PM
EH3-R's Avatar
what brand and color paint did you use to paint the tranny and block?
Old Nov 26, 2006 | 08:00 PM
B16A1-EF9's Avatar
It's called Detail Grey
Not sure who makes it but I can find out tomorrow when I get to the shop.
Old Nov 27, 2006 | 03:59 PM
mx621's Avatar
Default Re: (B16A1-EF9)
i like the ripped vin tag off the tranny
Old Nov 27, 2006 | 04:06 PM
xDicktonesx's Avatar
Default Re: (mx621)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mx621 &raquo;</TD></TR><TR><TD CLASS="quote">i like the ripped vin tag off the tranny </TD></TR></TABLE>
sadly i see sooooo many like that. cant decide if its a stolen type thing, or more likely, its so someone with and LS tranny can pass it off as a b16 tranny.
well anyway, good LOOKING set-up. hope it runs well... as far as the car itself goes you need: soap, water, a lip, and and a muffler that isnt from pep boys and youll have one nice looking bucket.
Old Nov 27, 2006 | 04:16 PM
mx621's Avatar
Default Re: (xDEFTONESx)
[QUOTE=xDEFTONESx]
after my **** got stolen earlier this year (all legit) i cringe every time i see that...
now every honda/acura i see around my way is a suspect..... it sucks...
Old Nov 27, 2006 | 04:23 PM
Default Re: (mx621)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mx621 &raquo;</TD></TR><TR><TD CLASS="quote">[
now every honda/acura i see around my way is a suspect..... it sucks... </TD></TR></TABLE>
i hear ya. i have had 2 jacked in a 5 month period. one with spoon wheels and carbon fiber everything. i cringe at the thought of what is going to happen when i roll up to a meet and see my parts on some poor schmucks car.
sorry, on with the thread
Old Dec 1, 2006 | 04:39 PM
SYNSEI's Avatar
Looking good. Keep us posted.
Old Dec 3, 2006 | 08:45 AM
B16A1-EF9's Avatar
First of all the transmission, I bought it from a very well known shop here in my town. The fact that the vin tag was broken off was not my fault its the way it came.
Anyway, I finally got it running using crome. We used ITBTools and got it to run but because there are so many map fluctuations it is very hard to cruise the car. It's fine when your at 0" vacuum. We just found out about ITBTools Plus and how we can adjust the point of TPS switch over. I'm going to try to make it switch over to TPS as soon as throttle is open, so like 2% or something. Hopefully that will make it fully TPS on load.
Old Dec 3, 2006 | 02:51 PM
BILLY_BLING's Avatar
nice set up would like to see some dyno numbers????????
Old Dec 3, 2006 | 02:54 PM
B16A1-EF9's Avatar
Well, with first gen automatic cams, stock ls exhaust manifold and stock cx exhaust it only made 157 whp. Here is the dyno run
Modified by B16A1-EF9 at 10:28 PM 12/6/2006
Old Dec 3, 2006 | 08:42 PM
UncleD's Avatar
That motor is DYING to be uncorked.
Old Dec 3, 2006 | 08:47 PM
Default Re: (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">That motor is DYING to be uncorked.</TD></TR></TABLE>
seriously, thats a 180hp motor with the shitty cams, just needs a decent header and exhaust. im all about the 2.5'' modded edelbrock for 135 bucks on the 1.8L motors. then put a whitfield street sweepin dump-pipe on it.
Old Dec 3, 2006 | 08:50 PM
B16A1-EF9's Avatar
you seriously think it will make 180 with the header and exhaust, even with those cams? Thats 20 horse....
Old Dec 3, 2006 | 09:17 PM
yep. cx exhaust is 1.75 inches and that ls manifold is tiny. 2'' collector. 20 horse from a stock manifold and ditching a old clogged cx cat as well....easy.
and if that cat is still on there and it is clogged thats another 5 hp easy.
i didnt see anything about a valvetrain because i skimmed over it but it will be ready for cams then. at which point cleanrice wil lchime in, cuz, thatts what he does.
Old Dec 4, 2006 | 05:52 AM
D-Rob's Avatar
Your engine is begging you for a set of nice cams.
Old Dec 4, 2006 | 04:43 PM
Mike@K-Tuned's Avatar
Default Re: (D-Rob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-Rob &raquo;</TD></TR><TR><TD CLASS="quote">Your engine is begging you for a set of nice cams.</TD></TR></TABLE>
I think he said in his first post that he has a set of Skunk2 Pro 1 cams to go in. I have heard very good things about the Pro 1's in mild 1.8L motors and almost bought a set. I am very interested to see what the numbers are like with the ITB's. It would be even better to see the ITB's dyno against a reworked ITR-style manifold. You "should" dyno more than 200whp with your setup. My current LSV setup in my sig makes 190whp and 136wtq through a cat and ITR muffler. You have ITB's, a better header and much bigger cams. Keep us posted.
Modified by LSvtecMike at 6:26 PM 12/4/2006
Old Dec 4, 2006 | 05:06 PM
Check out the numbers (esp. torque) on these dynos. The first build is using all OEM parts:
http://forums.evans-tuning.com...151tq
http://forums.evans-tuning.com...svtec
Old Dec 4, 2006 | 05:08 PM
dew_fever's Avatar
Default Re: (misaelmelchor)
Nice man, what type of lower control arms do you have?
yeah and what was done to this car before you had it...:'( makes me cry!
Old Dec 4, 2006 | 05:11 PM
B16A1-EF9's Avatar
The lower control arms are by Megan Racing.
Old Dec 6, 2006 | 06:34 PM
B16A1-EF9's Avatar
So I finally got my header in!!!!
I installed it right away...but since I only had the CX exhaust for the car I just took the whole thing out and ran it open headers for this dyno session.
What a difference, the car woke up right away!
The Rage header is amazing also, looks great and sounds good....plus it really does make power.
Here is the latest dyno graph.....still with the first gen automatic b16 cams
Old Dec 7, 2006 | 03:41 AM
Kafelatte's Avatar
what paint did you use to paint the block and tranny?
