93 accord slightly hesitates while starting?
Old Nov 26, 2006 | 03:12 PM
Mjfan12's Avatar
Default 93 accord slightly hesitates while starting?
my car takes about 2.5 seconds to get started when the key is turned, feels like a slight hesitation. the alternator gives out 14 volts so its good, but the battery is low on my $5 radio shack car battery tester. but i dont know if the batt is bad, or its because the car hasnt been driven much since the tie rods and ball joints are bad and im waiting to get them replaced.
so could it be because the batt is low and not enough juice at the start? could it be my starter?
doesnt autozone test the starter for free?
Old Nov 27, 2006 | 05:03 PM
hondadude's Avatar
Default Re: 93 accord slightly hesitates while starting? (Mjfan12)
define "hesitates"
you mean you turn the key to crank and then a pause before it starts cranking?
Or , you start the engine and it stumbles a little bit?
Sure the parts store will test the starter for free if you pull it out for them
Old Nov 27, 2006 | 05:21 PM
hb_guy's Avatar
cap and rotor? plugs? tune up?
poprocksncoke
Jan 28, 2017 04:56 AM
donboley
Jul 10, 2013 06:34 PM
jpep92wagon
Feb 13, 2012 12:37 PM
tr0n
Aug 14, 2008 06:33 PM
pecusio
Aug 16, 2004 06:50 AM
