Tig question about welding mild steel
Old Nov 26, 2006 | 02:25 PM
JDMCRX's Avatar
Default Tig question about welding mild steel
Ok im working on a fuel rail its 1/16" thick when im welding it im notice that there is alot of dark grey pin holes. Can having my argon up to 18-20psi be too high thats its cooling it down to fast?
Old Nov 26, 2006 | 03:54 PM
JDMCRX's Avatar
Default Re: Tig question about welding mild steel (JDMCRX)
Ok now im getting pissed at this thing. I tried gas high gas low the amps at 40-90 and i still get too hot of a weld?
WTF
Old Nov 26, 2006 | 04:36 PM
cleanxGSR's Avatar
15-20 psi that amount of gas should be enough. it might be porosity possibly from contamination did you clean the part good? also when you have a part that thin and small tube like the heat has no place to go making it harder to keep cool..
Old Nov 26, 2006 | 04:58 PM
JDMCRX's Avatar
Default Re: (cleanxGSR)
Yeah i cleaned it and dipped it in acetone. What filler should i use?
Old Nov 26, 2006 | 05:43 PM
ezmoneytrg's Avatar
Default Re: (JDMCRX)
if you are welding with the gtaw process which is tig you would want to use er70s-2,6 if you want a now hasle wire to run and fuseses good with all sorts or metal if you are using the gmaw process which is mig you wnat to use er70-s
Smashback
Welding / Fabrication
Dec 11, 2012 11:18 AM
sdubfid
Jan 12, 2008 06:54 PM
silentdaredevil2
Jul 3, 2006 07:51 AM
Flashmn
Oct 31, 2005 03:44 PM
GPoodle
Jan 13, 2004 03:06 PM
