RESISTOR BOX ON 89 CIVIC
Old Nov 26, 2006 | 02:10 PM
j-bird20's Avatar
Default RESISTOR BOX ON 89 CIVIC
okay...i have 89 civic si with a D16y8 motor in it.....does this car have a resistor box in it...cause im having trouble with my RC440's(saturated)....im pretty sure they dont have a resistor box
Old Nov 26, 2006 | 03:31 PM
e jay one's Avatar
Default Re: RESISTOR BOX ON 89 CIVIC (j-bird20)
its your car you should know. anywase pop the hood and look in the right corner near the windsheild is there a little silver box that sorta looks like a mini amp? what obd is your car? you can put obd0 injectors on that motor and run the resistor or you can use obd1 injectors and not need the resistor.
Old Nov 26, 2006 | 06:20 PM
j-bird20's Avatar
Default Re: RESISTOR BOX ON 89 CIVIC (e jay one)
its obviosly an ODB0 car with a d16y8 motor so thats OBD-2 and im runnin a P28 computer.....ill look for the resistor box......ill look on the right side and see if i see anything......its something is plugged in should i just take it out?
Old Nov 27, 2006 | 09:41 AM
e jay one's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-bird20 &raquo;</TD></TR><TR><TD CLASS="quote">its obviosly an ODB0 car with a d16y8 motor so thats OBD-2 and im runnin a P28 computer</TD></TR></TABLE>
so its obd1 then im guessing you didnt put the motor in so most likely there is no resistor box. you can make any motor any obd your d16y8 is orignaly a obd2 motor but its obd1 now cause you have an obd1 ecu. what are you trying to do again?
Old Nov 27, 2006 | 09:44 AM
e jay one's Avatar
ok if you dont want to run the resistor box you need obd1 injectors the you take the plug where the resistor box is and cut off the resistor box then solder all 5 wires together on that green plug. dont cut the plug off the engine harness cut the plug off the resistor box that way you could change it back if you need to.
Old Nov 27, 2006 | 04:54 PM
j-bird20's Avatar
i did put the motor in....but i havnt got a chance to see if thier is a resistor box...and no i have injectors for that motor d16y8(99 civic) OBD-2)....i dont think thier is a resister box...
Cap'N Chronic
Aug 30, 2011 02:39 PM
B16Chaser
Mar 16, 2008 07:35 PM
skoodles2k6
14
Sep 17, 2006 07:44 PM
RudeLude
Apr 22, 2006 07:36 AM
mouch33
Dec 21, 2005 05:44 PM
