AEM cam gears rubbing my upper cover....normal??
Old Nov 26, 2006 | 01:55 PM
drumminforev's Avatar
Default AEM cam gears rubbing my upper cover....normal??
I just switched from oem to aem and now the intake gear grinds on the distributor side...it will stop if i push the timing cover towards the distributor...wonderin if this happens to anyone else and if you know an easy way to stop it and keep the gears
And if this could cause any problems.
Old Nov 26, 2006 | 02:08 PM
RACEPAK's Avatar
Default Re: AEM cam gears rubbing my upper cover....normal?? (drumminforev)
post a pic.
Old Nov 26, 2006 | 02:09 PM
spoonracer84eg's Avatar
Default Re: AEM cam gears rubbing my upper cover....normal?? (RACEPAK)
Definately not normal
Old Nov 26, 2006 | 05:33 PM
platinum00's Avatar
the gear is the same size as stock, so no it's not normal.
are you sure you got all the bolts back in on the upper cover.
platinum
boosted k20
Nov 17, 2014 07:52 PM
NitrousB.I.G.
Aug 10, 2005 10:35 AM
kennymr22
Jan 3, 2005 09:09 PM
Clifton Santiago
Jul 18, 2004 06:00 AM
Stewie
Jan 16, 2003 07:22 PM
