DIY PAINT: Do I sand basecoat before clear or not and why?
So i just finished rattle can primer, base coat, its been drying for 18 hours now. Will i get better shine if i wetsand the base with something like 2000 and then clear coat...or will that make the paint look like crap after clearcoat is applied?
i have read both, plus it doesnt make sense to me to clear over a rough surface so anyone else with real world experience?
as far as I know you should have sanded the primer smooth, thus leaving a smooth surface after base coat. But I'm definately not an expert when it comes to this.
The primer did get sanded fully smooth with 400 wet sand, but when laying the paint it just doesnt go on smooth. I never have seen it lay on fully smooth as the primer was.
bump
bump
Depending on the paint manufacter you only have so long to spray clear after spraying base. Find out how long you have/had. If you waited to long the clear will not adhear properly without sanding. As far as the base not going on smoothly thats all in your hands prctice makes perfect. Check to make sure you have proper adjustments needed like air pressure.
EDIT: Is your basecoat rattle can too? If so thats why you have such a sloppy outcome. 2000 is to fine of a grit to sand base, go with 800-1000
yes... when i paint a car... i let the base dry and wet sand with 2000 or even higher, then lay one more coat of base, then clear.. it helps get rid of imperfections before you clear. BTW- i'm a body man by profession, not just a random shmoe telling you what he heard
everyone has so many different opinions
one guy says NEVER sand base
one says sand with 1000
one says sand with 2000
jebus.
This is duplicolor rattle can universal gloss black
jebus.
Well, I dont think there are tons of people out there that have rattle canned a car and then cleared it. How well will clear coat stick to a gloss paint anyway?
You might have to just try it and see.
i was always told not to sand the base before clear UNLESS there were serious runs or something like that. ive painted my car twice now and both times have not sanded between base/clear
Ok check it out. my base coat has expletive ups in it. not completely smooth and a few runs. so if i sand it then clear it will it be permanently hazy since i wont polish the base?
You Should Only Sand the Base-Coat where the are imperfections I.e to fix runs, dings ect.. After you clear you will not be able to go back and fix these... How was the body before..? Did the whole car NEED primer... If not you may have caused yourself more greif than necessary... and I hope you didin't primer ANYTHING plastic... you will find your paint flaking off readily... Hope this helps...
dont know how the weather is there but here its freezing and i learned not to paint anything in the cold weather unles i have ti done at a shopor a heated room. everything turns out better when its hot out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by williejohnson »</TD></TR><TR><TD CLASS="quote">i stoped reading when i saw
rattle can primer
WTF is that supposed to mean. there is nothing wrong with rattle can primer. and i dont plan on opening a shop up in my apartments parking lot with a tent and clean room just to paint my hood and fender.
and no i used adhesion promoter on the plastic.
rattle can primer
</TD></TR></TABLE>WTF is that supposed to mean. there is nothing wrong with rattle can primer. and i dont plan on opening a shop up in my apartments parking lot with a tent and clean room just to paint my hood and fender.
alright, so im gonna wetsand the parts that are jacked and lay some base down over those parts only.
IF you get dust in the paint you will want to sand it out before you clear....but remember....how the surface looks before clear is how its going to look after clear....
what I'm saying is, you can't just sand and leave the sanding scratches there...you have to buff them out completly...THEN clear over it......
IF you get dust in the paint and DONT sand it out, then clear over that, you will have the dust under the clear.....duhh....fisheyes....its not gunna look good.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumminforev »</TD></TR><TR><TD CLASS="quote">
and no i used adhesion promoter on the plastic.</TD></TR></TABLE>
well 2k primer is deff. better....it hides imperfections and is alot easier to work with when sanding......
drumminforev
16
Feb 19, 2023 09:18 PM
