b16 quick question..
Old Nov 26, 2006 | 11:22 AM
94eh2's Avatar
Default b16 quick question..
alright guys heres my question..i will be swapping a b16 into my eg hatch(dx) ..my question is will everything go smoothly? what new motor mounts do i need ..will it be a much more different swap from a stock motor swap? besides the harness and ecu what other things would i need to make this a successful swap..thanks .i would prefer answers from people who have done this swap previously..
Old Nov 26, 2006 | 11:25 AM
Suck my DX's Avatar
Default Re: b16 quick question.. (305accord)
FAQ sticky at the top of the page...search before you ask a question that has literally been covered over a million times
Old Nov 26, 2006 | 11:35 AM
94eh2's Avatar
Default Re: b16 quick question.. (Suck my DX)
listen here dickwad i have searched 30 times but i want str8 answers not to read and essay.ok all i want is for a respectively memeber to say do this get this and thats it
Old Nov 26, 2006 | 11:57 AM
Suck my DX's Avatar
good luck dickwad
Old Nov 26, 2006 | 12:02 PM
BlueIntegraBoy's Avatar
1. Everything will go smoothly unless you are not prepared.
2. What model car is the B16 coming from? (if EG6 or EG2, then no need for new mounts, reuse stock)
3. It will bolt in, but you'll need to wire VTEC solenoid, VTEC pressure switch, and knock sensor (if using P30).
4. You need axles and shift linkage.
Old Nov 26, 2006 | 02:20 PM
spoonracer84eg's Avatar
Default Re: b16 quick question.. (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 305accord &raquo;</TD></TR><TR><TD CLASS="quote">listen here dickwad i have searched 30 times but i want str8 answers not to read and essay.ok all i want is for a respectively memeber to say do this get this and thats it</TD></TR></TABLE>
Calling people a "dickwad" will not get you very much help Oh and by the way it has been covered a million times.
Old Nov 26, 2006 | 05:17 PM
94eh2's Avatar
Default Re: b16 quick question.. (spoonracer84eg)
thanks integra boy..well it will most likely becoming out of an integra..can i use the axels and shift linkage off the car its coming off?
Old Nov 26, 2006 | 08:11 PM
egmatt93's Avatar
i have this EXact set-up and the only thing that isnt proper is my tranny mount and im not sure but i beleive it is because my car was auto b 4 the swap so u might want to look into that
Old Nov 27, 2006 | 11:54 AM
94eh2's Avatar
Default Re: b16 quick question.. (egmatt89)
gmatt did you have any problems besides the transmission mount?
Old Nov 27, 2006 | 12:06 PM
RaYnE's Avatar
i didnt have any problems per say, but there were a few things that i needed to research to find, such as proper mounts, pinning your new ecu for vtec.
i had a pretty easy time for my first swap, went smoothly. took about 8h start to running.
theres a picture somewhere that gives the proper mounts which i dont know where it is on here.
Old Nov 27, 2006 | 12:07 PM
H9Omega's Avatar
If it is coming out of a 2nd generation integra, than you will need a hydraulic transmission, otherwise all the mounts from a 3rd generation integra will work. You can still use your stock civic tranny mount and rear mount.
barzano724
Nov 12, 2013 08:50 AM
redlinexd
17
Oct 8, 2008 06:10 PM
DenzComp
May 12, 2007 09:07 AM
DenzComp
May 12, 2007 12:09 AM
ablack934doorcivic
Jul 9, 2004 12:32 PM
