B20Vtec, Blox B, and intake valve closing ABDC questions...
Old Nov 26, 2006 | 11:10 AM
MARVNVRAM's Avatar
Default B20Vtec, Blox B, and intake valve closing ABDC questions...
I'm trying to calculate my dynamic c/r and have questions.
1. Is there a formula to find intake valve closing ABDC, in degrees, using my camshaft specs?
2. Does anyone know, more or less, at what c/r the Blox B's like to shine?
Old Nov 26, 2006 | 02:57 PM
Natural Aspirations's Avatar
Default Re: B20Vtec, Blox B, and intake valve closing ABDC questions... (MARVNVRAM)
Call blox, they will help you out.
Old Dec 2, 2006 | 03:31 PM
MARVNVRAM's Avatar
Default Re: B20Vtec, Blox B, and intake valve closing ABDC questions... (Natural Aspirations)
Ok, but what about generally speaking....regardless of the manufacturer, as long as I have the specs there's no way to calculate this? Or would I need something like a degree wheel and go from there to find this out?
Ninja Edit: here's the calculator I'm using if it helps: http://www.wallaceracing.com/dynamic-cr.php
Old Dec 6, 2006 | 02:19 PM
MARVNVRAM's Avatar
anyone?
Old Dec 6, 2006 | 02:45 PM
DonF's Avatar
Call BLOX, they should be able to give you the numbers. You need primary and secondary closing events as you do have more than one cam profile in a VTEC.
Old Dec 6, 2006 | 02:55 PM
Rocket's Avatar
Default Re: B20Vtec, Blox B, and intake valve closing ABDC questions... (DonF)
52 ABDC at 0.050" lift would be a number that would work provided you can do all of the following:
Properly set up a degree wheel accurately dialed to read zero TDC when your #1 cyl. piston is at TD, axially align your indicator to your valve, locked VTEC, Zero Lash, timing belt installed as it would be when the engine is running, check and correct for acceptable v-v and p-v clearances.
Old Dec 6, 2006 | 04:11 PM
MARVNVRAM's Avatar
thanks for the help
wagon-r
Jun 11, 2013 09:32 AM
sick_dc2
Nov 22, 2008 01:33 AM
h8ted ek
Jul 31, 2006 05:07 PM
sbcs15
Sep 12, 2005 09:46 PM
Wookey
Jan 18, 2005 03:56 AM
