turbo mani bolts vibrate out
Old Nov 26, 2006 | 09:21 AM
racin jasin R's Avatar
Default turbo mani bolts vibrate out
my dam turbo mani bolts keep vibrating out.any ideas that WORK!!!had the allen bolt and those even vibrated out #@*#&.
Old Nov 26, 2006 | 09:28 AM
Boilermaker1's Avatar
lock washers, deformed thread locknuts and studs, double nuts, it goes on and on. There's lots of easy solutions.
Old Nov 26, 2006 | 09:31 AM
EK k kay's Avatar
Default Re: (Boilermaker1)
I use copper locknuts for the manifold, turbo, and downpipe. I also double nut two of the turbo to manifold bolts. No problems here.
Old Nov 26, 2006 | 09:54 AM
Default Re: (EK k kay)
guess there SCREWS.they are the onese that screw the turbo no to the mani.allen screws fell out dam...
Old Nov 26, 2006 | 11:08 AM
a1320addict's Avatar
Default Re: (racin jasin R)
blue lock-tite.
Old Nov 26, 2006 | 11:14 AM
tuned_vtec
Guest
Posts: n/a
Default Re: (a1320addict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320addict &raquo;</TD></TR><TR><TD CLASS="quote">blue lock-tite.</TD></TR></TABLE>
This worked for me as well...and you can get them back out without too much trouble.
Old Nov 26, 2006 | 11:22 AM
RCautoworks's Avatar
Default Re: (tuned_vtec)
* 100% reliable, zero failures in more than 6,000,000 applications. Header fasteners absolutely, positively will not back out. Eliminates need to monitor and tighten bolts regularly
* Grade 8 aircraft quality bolts made in U.S.A. Duplex nickel plated
* Manufacturer’s Lifetime Warranty
* NOTE: ¹ Will not fit 4.6L/5.4L modular V-8
Old Nov 26, 2006 | 11:29 AM
97gsrki's Avatar
i tac welded my bolts to the turbo. small enough so that they can be easily broken with a wrench. it has done the trick for me.
Old Nov 26, 2006 | 11:33 AM
MotorMouth's Avatar
Default Re: (97gsrki)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">
* NOTE: ¹ Will not fit 4.6L/5.4L modular V-8</TD></TR></TABLE>
Where do you get those? they look like the best thing since sliced bread.
Old Nov 26, 2006 | 11:38 AM
Default Re: (MotorMouth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMouth &raquo;</TD></TR><TR><TD CLASS="quote">
Where do you get those? they look like the best thing since sliced bread.</TD></TR></TABLE>
Try summit, I know they are mostly for American cars but getting them to work with imports should not be to hard.
Old Nov 26, 2006 | 12:09 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: (90blackcrx)
i prefer red-loctite. but those bolts look like a good alternative
Old Nov 26, 2006 | 12:33 PM
jtracing919's Avatar
Default Re: turbo mani bolts vibrate out (racin jasin R)
safety wire solved the problem for me..
Old Nov 26, 2006 | 01:28 PM
alpha's Avatar
Clean out the threads. Use a little red Loc-Tite after
Old Nov 26, 2006 | 01:55 PM
BlueSi2k's Avatar
Default Re: turbo mani bolts vibrate out (alpha)
Take a small worm hose clamp and tighten it around the head of the bolt after you tighten the bolt down. Back the screw part against the turbo housing so the bolt cant turn. Costs like nothing and works great.
Old Nov 26, 2006 | 04:34 PM
Laserjock's Avatar
Default Re: turbo mani bolts vibrate out (BlueSi2k)
Loktite is only good for 400 degrees F. Pretty sure my mani gets waaaayy hotter than that. Sad that I still have to point misconception that out.
Old Nov 26, 2006 | 04:36 PM
biada1's Avatar
Default Re: turbo mani bolts vibrate out (Laserjock)
i have the same problem...... drag kit.... maybe if i add a flex pipe to my downpipe, it should help reduce the vibration?
Old Nov 26, 2006 | 06:23 PM
Default Re: turbo mani bolts vibrate out (biada1)
I will try red lock tight first. if that doesn't work let me get some of those bolts!!!
Old Nov 26, 2006 | 06:26 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueSi2k &raquo;</TD></TR><TR><TD CLASS="quote">Take a small worm hose clamp and tighten it around the head of the bolt after you tighten the bolt down. Back the screw part against the turbo housing so the bolt cant turn. Costs like nothing and works great.</TD></TR></TABLE>sorry ,but do you have a pic.cause this sound like it will work!!!
Old Nov 26, 2006 | 06:34 PM
Tchleung's Avatar
Screw the blue and red loctite, step up to taht green and yellow loctite. Green can be found almost anywhere, yellow is specialty.
Genereally red loctite is good enough, regardless of temperature rating
Old Nov 26, 2006 | 06:40 PM
Default Re: (Tchleung)
thanks
Old Nov 26, 2006 | 06:41 PM
igo4bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMouth &raquo;</TD></TR><TR><TD CLASS="quote">Where do you get those? they look like the best thing since sliced bread.</TD></TR></TABLE>
http://www.stage8.com
Old Nov 26, 2006 | 06:53 PM
HamiltonRex's Avatar
Default Re: (igo4bmx)
i used redloctite on everything, all last season and not once bolt loosened up once (on the turbo setup that is )
Old Nov 26, 2006 | 06:56 PM
dunkd's Avatar
lock washers are the cheapeast/easiest solution.
Old Nov 26, 2006 | 07:13 PM
Default Re: (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">lock washers are the cheapeast/easiest solution.
got those washers but still coming out
Old Nov 26, 2006 | 07:52 PM
allstokhonda's Avatar
Had a similar problem with my inline pro turbo manifold. The bolts the hold the turbo on keep backin out, falling out. So, I just got two small pieces of metal and tack welded them to the heads of the bolts. Problem solved. The stage 8 stuff is great. Just was in a bind and had to fix it then. Well be going with those when I get my new turbo.
-Chad-
