tps question?
ok my car is throwing a code 7 which is tps sensor. I replaced it when i put the motor in, and i know i need to calibrate the sensor. I know how to do this but my question is, if the calibration is off can it cause the car to rev slower than normal??? my car rev's but seems a little sluggish revving up. I just put this motor in and this is the only code i'm getting. is it possible or is it something else?? any ideas? tia
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken »</TD></TR><TR><TD CLASS="quote">If you did a swap and went from DPFI to MPFI then you needed to swap the two wires on the TPS sensor (I think its the outer two wires dont quote me) </TD></TR></TABLE>
i know all of this guys i had a zc in there before i put a d16z6 in. the wires are swapped, all i need to know is if it's possible for the tps to be making my car rev slower?
i guess theoretically its possible, if your out of adjustment, you would run either too rich or too lean depending on which way its off....and a bad air/fuel mixture would rob you of power giving you a slower rev...but i don't think that it would be to the point where you would significantly notice it
ok i fixed the tps, i really don't see any difference coming of it but it's fixed; no code 7.
but my problem still remains to where my car is revving up slowly and bogging!!! any ideas? please help?
Hcivic88
17
Apr 27, 2004 09:23 PM
mugenwannabe
Jan 22, 2004 12:52 PM
