Mugen Headgasket install, same torque spec?
Old Nov 26, 2006 | 06:48 AM
crexer's Avatar
Default Mugen Headgasket install, same torque spec?
I will be installing a Mugen headgasket on my gsr and was curious to know since it is thinner than a oem headgasket does it require the same torque spec of 65lbs?
Old Nov 26, 2006 | 07:07 AM
dbiker207's Avatar
Default Re: Mugen Headgasket install, same torque spec? (crexer)
yes
Old Nov 26, 2006 | 04:59 PM
crexer's Avatar
Default Re: Mugen Headgasket install, same torque spec? (dbiker207)
anyone else confirm this?
Old Nov 26, 2006 | 07:51 PM
crexer's Avatar
Old Nov 26, 2006 | 09:10 PM
crexer's Avatar
no one has bought a mugen headgasket and used it? what did you torque the head to?
Old Nov 27, 2006 | 03:52 PM
crexer's Avatar
help
Old Nov 27, 2006 | 06:56 PM
boost'd_crx's Avatar
same as factory spec
Old Dec 1, 2006 | 07:15 AM
crexer's Avatar
Default Re: Mugen Headgasket install, same torque spec? (boost'd_crx)
any gurus care to chime in?
Old Dec 1, 2006 | 07:49 AM
Natural Aspirations's Avatar
Very few guys would spend the money Vs. taking out the center layer of the OEM gasket. The head gasket has nothign to do with your Tq numbers its in the head bolt and engine material. So if you are using stock head bolts it will require stock bolt tq.
Old Dec 1, 2006 | 12:53 PM
d16dcoe45's Avatar
Default Re: (Natural Aspirations)
two people have answered your question, but its not good enough for you? What would make it need a different spec? Its the same type of HG, correct? Its a multi-layer-steel. Torque it to stock specs.
Old May 24, 2007 | 08:39 AM
MadSuRfEr's Avatar
Default Re: (d16dcoe45)
up because i need to know also
Old May 24, 2007 | 12:56 PM
crexer's Avatar
Default Re: (MadSuRfEr)
everyone said same as oem specs.... where in nc are you located?
Old May 24, 2007 | 01:17 PM
Jay_Sensing's Avatar
Yes, for the 4th time, use whatever the tq spec for your bolts are, if stock (don't see why you would reuse those) it's stock spec, if ARP's, then use ARP spec. Just like Natural Aspirations said, it has nothing to do with the gasket itself.
MelloYelloCRX
Jun 30, 2007 09:30 PM
tremor86
Jul 4, 2004 04:22 AM
tremor86
Jul 3, 2004 03:14 PM
Yusuke
Oct 23, 2003 08:23 AM
ispteg
Aug 21, 2002 03:16 PM
