crx si cam
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueRex1020 »</TD></TR><TR><TD CLASS="quote">i know, ive heard they are...but wouldnt a 1.6 cam in a 1.5 motor cause a slight timing issue?</TD></TR></TABLE> We have a winner! An adjustable cam gear is your friend, or be prepared for a 4 degree timing issue.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dkrex001 »</TD></TR><TR><TD CLASS="quote">yes it will fit
with the si cam and intake manifold and the cam advanced 4 degrees it will pull harder than a stock si will</TD></TR></TABLE> How about not really
4 Degrees of timing does not make up for 100cc's of displacement; Maybe on the butt dyno, but no where else. Besides, do you really want your valves 4 degrees out of sync with your pistons on a tired old motor?
hay i did it and it pulled harder than my friends si
and the car will run like s**t if you do not advance the cam any ways
it will have no dottem end
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueRex1020 »</TD></TR><TR><TD CLASS="quote">so those 4 degrees wouldnt really hurt?</TD></TR></TABLE> I'm still putting my foot down on the concept of Cam should be in time with crank, just because I hate my motor running out of spec.
yeah a cam gear would fix the problem. I woldn't go more then 3 degrees advance/retard. if you retard it you should get more top end, and advancing it will give you alittle more down low.
