Radio Wiring diagram 94 Civic. Some one cut my wiring harness for radio
Help, some one jacked my radio and they cut my wiring harness. which color is witch? i want to put a new harness back on the end but i dont know wich wire is witch.
If you're not comfortable soldering and testing wires with a voltmeter, I strongly suggest you take it somewhere and pay the $35. I recommend Circuit City. If you are comfortable with soldering, go over to http://www.the12volt.com, register, then look up the diagram. All Civics are pretty much the same colors.
http://www.installdr.com/Harnesses/HA-Wiring.pdf dont know if this helps but i used this diagram to install my cd player.
seraphin
May 26, 2015 03:07 PM
ryan ortego
Feb 12, 2005 07:07 PM
