tranny ???? 60mph at 3000 rpm on ls tran
ok so i was wondering how come my ys1 is putting so high of a rpm at just 60mph
5th gear
Modified by jdmboi86 at 9:51 PM 11/25/2006
5th gear
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autopro01 »</TD></TR><TR><TD CLASS="quote">what gear r u in if ur in 3rd it is normal</TD></TR></TABLE>
Sounds totally normal to me, LS transmissions sit at around 3k at 60 mph in 5 gear. And I dont know why you said it changed. If thats the case something before was probably messed up and its reading accurately now because thats what it shouldbe reading.
And for you guys that think its a gsr trans, GSR's are close to 4k at 60mph.
^^ So wrong.... GSR Tranny sits at 3k at 60 mph with 195-50-15's! LS is lower than 3k for sure! My friend has a ls tranny... and his RPM is lower than 3k at 60 MPH!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsDAteg »</TD></TR><TR><TD CLASS="quote">Sounds totally normal to me, LS transmissions sit at around 3k at 60 mph in 5 gear. And I dont know why you said it changed. If thats the case something before was probably messed up and its reading accurately now because thats what it shouldbe reading.
And for you guys that think its a gsr trans, GSR's are close to 4k at 60mph.</TD></TR></TABLE>
A GSR's rpm will be your speed in MPH divided by 2. So it would be 4k at 80, 3k at 60, 2k at 40.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b20acura »</TD></TR><TR><TD CLASS="quote">ok i have a gsr tranny, and at 60mph im at 3k sharp. at 80 mph im at aboout 7600ish take or give a few.</TD></TR></TABLE>
7600ish huh? that sucks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 »</TD></TR><TR><TD CLASS="quote">well do any one know wat a a1 tranny run in 5th and a 92-93 gsr </TD></TR></TABLE>
http://www.fatboyraceworks.com/gears/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohboitony »</TD></TR><TR><TD CLASS="quote">^^ So wrong.... GSR Tranny sits at 3k at 60 mph with 195-50-15's! LS is lower than 3k for sure! My friend has a ls tranny... and his RPM is lower than 3k at 60 MPH! </TD></TR></TABLE>
I was talking about DA's. I'm not sure if DC's have longer gearing than a DA (I dont believe they do) but I know what I posted is absolutely correct for DA's. I have owned 3 non-gsr DA integra's and every one had stock trannies and they all sat at 3k while doing 60mph. Dont believe me, go on to g2ic.com and ask some of those guys. That is completely normal for a DA integra.
And the GSR I was talking about was a gen 2 also, they sit close to 4k at 60mph. I believe they are the shortest geared Honda transmission ever.
^ They have a slight difference, not hugely, but enough that it's not the same.
The OP made this a lot more confusing by Not stating nearly enough information.
there is a lot of variable to figure out what tranny is on there i had a gsr tranny on my ls-t and it sat at 3k at about 60 and i couldnt deal with it so i bought an ls and it does the same dam thing. Im pretty sure it depends on how u drive it to also hills and hp and rim/tire size ya know.
