bolt broke n block, a little help asap pleas
Old Nov 25, 2006 | 07:45 PM
joethejoeman's Avatar
Default bolt broke n block, a little help asap pleas
ok, i had a code 21 and i was cleaning my screen, then when i was putting the silonoied back on one of the bolts broke off into the block,
i was wondering if any one new how to go about as to fix this problem
Old Nov 25, 2006 | 08:03 PM
ryanplayjoint's Avatar
Default Re: bolt broke n block, a little help asap pleas (joethejoeman)
If it broke off fluch with the head your going to have to drill it out, it sucks or if theres a bit of a nub left get ahold of it with small vise grips or a real good pair of pliers.
Old Nov 25, 2006 | 08:15 PM
Iron_Forrix's Avatar
recommendations ive recieved (cause i was at risk for tearing the head off) was to re-bore it.
clear off the torn part and drill it to something that can fit into it to twist it out. Exampe like what i did today. i stripped some phillips screws so i cut slits into them to use a flat head. worked like a charm.
Old Nov 26, 2006 | 03:32 AM
Default Re: (Iron_Forrix)
thank u so much,
i appriciate the help
Old Nov 26, 2006 | 10:05 AM
oh yeah that cutting flat heads into it is good one too. I forgot about that one.
Old Nov 26, 2006 | 10:23 AM
B6tizzleHatch's Avatar
Default Re: (ryanplayjoint)
use an "easy out" those things kick ***, it saved me on a camshaft cap bolt (whatever the proper name is)
Old Nov 26, 2006 | 10:57 AM
white ef's Avatar
tell me how this worked out. my dad left today for virginia, and that kid came buy to pick up the 89 hatch. tell me if i need to get you another bolt.
Old Nov 26, 2006 | 01:12 PM
Default Re: bolt broke n block, a little help asap pleas (pwrltbmx)
i cut the flat head and it didnt work it broke more of the bolt,
i think im stuck w\ ez out
tegboy321
21
Jul 28, 2013 02:58 PM
DeeEx Rex
10
Jul 29, 2010 11:02 AM
sh!ft
Dec 20, 2009 05:02 PM
blackprelude92
Oct 25, 2009 09:59 AM
spooledex
Nov 5, 2006 08:22 PM
