Suspension & Brakes Theory, alignment, spring rates....
installing strut bar on eg hatch.
Old Nov 25, 2006 | 05:58 PM
bluesihatch's Avatar
Default installing strut bar on eg hatch.
i was told one time that the proper way to install a strut bar is to lift your vehicle off the ground first and then tighten everything. is this true?
Old Nov 26, 2006 | 12:13 PM
BlueIntegraBoy's Avatar
Default Re: installing strut bar on eg hatch. (bluesihatch)
No, you don't have to lift your vehicle.
Old Nov 27, 2006 | 11:59 AM
bluesaint's Avatar
is this a joke?
when you lift your car, after you loosen your shock tower bolts, the shock will get dropped a bit, it will mess you up more than it helps you when installing strut bar.
Old Dec 4, 2006 | 10:46 AM
b18LS's Avatar
are you sure they werent talking about a sway bar? Not a good idea to lift your car while your strut mount bolts are off.
rich_one1
Mar 23, 2011 04:11 PM
JMelt4
42
Feb 23, 2007 05:53 AM
mrdeadman
Apr 20, 2006 04:24 PM
Bone Stock
May 4, 2004 12:30 AM
gribbs
Apr 24, 2002 01:48 PM
